Commander Sasha Posted May 17, 2009 Share Posted May 17, 2009 A question from my 10yr old has me chasing my head in circles: A Vet with a thunder hammer gets 2 std attacks at S8. If he hits a unit of 3 Necron scarab swarms T3 W3, and gets lucky so both attacks hit, how many scarab swarms are removed? i) 1 swarm IDed, then another ii) Both hits are on the same model, so 1st wound, then 2nd, ID removes last, so only 1 swarm removed, Link to comment https://bolterandchainsword.com/topic/168789-assigning-multiple-instant-deaths/ Share on other sites More sharing options...
Maligoare Posted May 17, 2009 Share Posted May 17, 2009 Assuming his luck nets him two successful wound rolls, two scarab swarm bases die, one per unsaved ID-causing wound, as per the bottom right quarter of P26 of the BRB. Link to comment https://bolterandchainsword.com/topic/168789-assigning-multiple-instant-deaths/#findComment-1991408 Share on other sites More sharing options...
Lord Humongous Posted May 18, 2009 Share Posted May 18, 2009 As noted, unsaved instant death causing wounds must always be assigned to an unwounded model if possible, and that model is removed before assigning further unsaved wounds. So not only would the TH remove one scarab swarm per wound it caused, but if there was a wounded scrab base, it would be the LAST one to get instant killed. Link to comment https://bolterandchainsword.com/topic/168789-assigning-multiple-instant-deaths/#findComment-1991551 Share on other sites More sharing options...
