Blessed Knight Posted May 18, 2009 Share Posted May 18, 2009 on foot. with classic tech pad rather than mechanicum http://i20.photobucket.com/albums/b246/blessedknight/100_2470.jpg on bike http://i20.photobucket.com/albums/b246/blessedknight/100_2474.jpg Beamer control arm. (will have clear screen control) http://i20.photobucket.com/albums/b246/blessedknight/100_2472.jpg side view of beamer http://i20.photobucket.com/albums/b246/blessedknight/100_2471.jpg Repair table with damaged backpack http://i20.photobucket.com/albums/b246/blessedknight/100_2475.jpg Link to comment Share on other sites More sharing options...
Terminatorinhell Posted May 18, 2009 Share Posted May 18, 2009 wow, i hope he doesnt fall over with that huge gun. :D But really it looks awesome and all the little bits you used I wouldnt even imagine using for a conversion beamer! Link to comment Share on other sites More sharing options...
INKS Posted May 19, 2009 Share Posted May 19, 2009 you should bulk out the hammers head more. can we see a better shot of the item by his hand? is that a control panel? Link to comment Share on other sites More sharing options...
paulson games Posted May 19, 2009 Share Posted May 19, 2009 Interesting build, looks a bit top heavy but good. I'd like to see better shots of the backpack structure from the rear showing where the arms attach so I can see how everything ties together. I'd suggest angling the corners of the bike's worktable a bit, having them jutting straight out makes it look kinda plain and would be a liability in the field as they'd catch on lots of stuff. If you rounded the front corners or cut them at about a 45 degree angle it'd be a bit less jarring, I'd also suggest building a tiny lip along the end as you wouldn't want tools and parts rolling off. With a lip it'd resemble a large scale version the wheeled work carts that you see around the auto shop. http://www.lighttruckbiz.com/images/article/1198080883524_np2_14.jpghttp://www.materialflow.com/global/images/part_class_images/thumbs/tlift-and-tilt-cart1243-.jpg Link to comment Share on other sites More sharing options...
cathar the great Posted May 19, 2009 Share Posted May 19, 2009 Very interesting build! I love the little workplace on his bike and you used a lot of very interesting bitz-combinations. How did you build the left hand? Is it sculpted or cut from bits? Or is it from an existing mini I forgot about? ^^ Link to comment Share on other sites More sharing options...
wiplash Posted May 19, 2009 Share Posted May 19, 2009 bulk out the hammer and it will look much better nice concept though very different to any techmarine i have ever seen Link to comment Share on other sites More sharing options...
Blessed Knight Posted May 19, 2009 Author Share Posted May 19, 2009 How did you build the left hand? Is it sculpted or cut from bits? Or is it from an existing mini I forgot about? ^^ its a standard left hand that holds a bolter, just with the fingers separated. for the hammer, the lightness is intentional. its his tool rather than war-hammer. (last thing he wants to do when re-rivetting his bosses prize land raider is to destroy it with a miss timed swing.) ;) for the bike, its a bit like the orange truck in the pic. (just closed) there isn't a lip as he uses magnets. (thats my story and i'm sticking to it) ;) (as its already been base-coated) :D for the control arm... i'm adding a clear screen (bit like the computer screen off minority report) these earlier WIP's may show the backpack layout better, but the shots of the control arm are the only ones i have. http://i20.photobucket.com/albums/b246/blessedknight/100_2469.jpg http://i20.photobucket.com/albums/b246/blessedknight/100_2468.jpg http://i20.photobucket.com/albums/b246/blessedknight/100_2467.jpg Link to comment Share on other sites More sharing options...
rusty1109 Posted May 20, 2009 Share Posted May 20, 2009 Hi, I love the originality, it's definately different. Not sure the terminator legs work with the regular body, doesn't quite look right. And would he remove a backpack and repair it mid battle? And if it's not mid battle why is it on wheels? The overall effect does look very cool though so if your not too concerned about that then i say thumbs up! Very impressed with your use of all sorts of bits as well. Link to comment Share on other sites More sharing options...
Blessed Knight Posted May 25, 2009 Author Share Posted May 25, 2009 Finished Bod!!! http://i20.photobucket.com/albums/b246/blessedknight/FORGEMASTER1.jpg http://i20.photobucket.com/albums/b246/blessedknight/FORGEMASTER2.jpg just need sand for the base (which i can't buy till Early June - Pesky holidays!) :blush: Close up of the control screen. http://i20.photobucket.com/albums/b246/blessedknight/SCREEN.jpg Link to comment Share on other sites More sharing options...
Dorns Padawan Posted May 25, 2009 Share Posted May 25, 2009 sweet!!! ;) Link to comment Share on other sites More sharing options...
ShinyRhino Posted May 26, 2009 Share Posted May 26, 2009 Not too shabby! Would have liked to have seen the supprting struts for the gun be a little bigger, but not a major issue. Pack him carefully for transport though. He is wearing two belts, however. Common oversight when trying to use Terminator legs and a PA chestplate. Link to comment Share on other sites More sharing options...
Blessed Knight Posted May 26, 2009 Author Share Posted May 26, 2009 I decided against removing the PA belt. i wanted it as part of the harness not the armour. Link to comment Share on other sites More sharing options...
