terrawitchunter Posted May 20, 2009 Share Posted May 20, 2009 I have some Warhound titan templates but they dont have any kind of tabs on them. how should i put it together? Link to comment https://bolterandchainsword.com/topic/169045-warhound-titan-build/ Share on other sites More sharing options...
Brother Styphus Posted May 21, 2009 Share Posted May 21, 2009 Make your own tabs? Use thicker card and just glue the edges? Use support pieces of card in the corners to hold shape? (Why did I ask all those questions instead of just listing them?) Link to comment https://bolterandchainsword.com/topic/169045-warhound-titan-build/#findComment-1995105 Share on other sites More sharing options...
ilnar Posted May 21, 2009 Share Posted May 21, 2009 dont use paper:P at least not for the legs. get yourself some plasticard:) Link to comment https://bolterandchainsword.com/topic/169045-warhound-titan-build/#findComment-1995594 Share on other sites More sharing options...
BulldogUK Posted May 21, 2009 Share Posted May 21, 2009 I found the most effective way is to assemble it in your head and mark off the tabs with a pencil, simply cut and score as normal then. I use standard cardstock for 99% of my models, mounting card for the parts that need to be stronger :) Link to comment https://bolterandchainsword.com/topic/169045-warhound-titan-build/#findComment-1995660 Share on other sites More sharing options...
terrawitchunter Posted May 21, 2009 Author Share Posted May 21, 2009 im using stockcard and i need to know a good place to get plasticard Link to comment https://bolterandchainsword.com/topic/169045-warhound-titan-build/#findComment-1995825 Share on other sites More sharing options...
