ChainsawDR Posted May 22, 2009 Share Posted May 22, 2009 Hi all, I've applied transfers to my SW's and they are shiny and look out of place. I presume that spraying them with matt varnish will stop this, but I wanted to double check if this is the best way or to do something else (I'll still be matt varnishing them anyway). Thanks all. ChainsawDR Link to comment https://bolterandchainsword.com/topic/169150-shiny-shoulder-transfers/ Share on other sites More sharing options...
Vassakov Posted May 22, 2009 Share Posted May 22, 2009 Matt Varnish and/or Dullcote, available from all good model and hobby shops (but not GW...) Link to comment https://bolterandchainsword.com/topic/169150-shiny-shoulder-transfers/#findComment-1996732 Share on other sites More sharing options...
ORKILL Posted May 22, 2009 Share Posted May 22, 2009 Use some decal set before spraying them. Your models will thank you. Link to comment https://bolterandchainsword.com/topic/169150-shiny-shoulder-transfers/#findComment-1996839 Share on other sites More sharing options...
Valhalla Posted May 22, 2009 Share Posted May 22, 2009 Matt Varnish and/or Dullcote, available from all good model and hobby shops (but not GW...) Once you've finished painting and putting on the decals cover the model with varnish to both take away the shine and also to protect your paint work. I'd recommend a gloss coat first followed by a matte one. The Gloss will offer more protection and the matte will take way the shine. Link to comment https://bolterandchainsword.com/topic/169150-shiny-shoulder-transfers/#findComment-1996955 Share on other sites More sharing options...
jester262 Posted May 22, 2009 Share Posted May 22, 2009 Use some decal set before spraying them. Your models will thank you. I agree. Use microsol on your decals. It actually melts the decal a bit and makes it look like it's been painted on Link to comment https://bolterandchainsword.com/topic/169150-shiny-shoulder-transfers/#findComment-1997128 Share on other sites More sharing options...
Beef Posted May 22, 2009 Share Posted May 22, 2009 whats the equivalent of that in the UK Link to comment https://bolterandchainsword.com/topic/169150-shiny-shoulder-transfers/#findComment-1997225 Share on other sites More sharing options...
KiltedMarine Posted May 23, 2009 Share Posted May 23, 2009 I think it goes by the same name, but I'm not sure... The procedure I have followed, per my time in the trenches as a red shirt lo those many years ago, is the following: Paint model Apply 'ard coat to area on which decal will sit. Let dry. Apply Micro-Sol to area. Apply decal. Brush Micro-Sol over decal. Let dry. Repeat as needed for decal to fully lie down/dissolve. Apply 'ard coat over dried decal. Let dry. Spray with Matte Varnish. The rationale for the multiple layers of 'ard coat is to make the area around the decal match the shininess of the transfer itself, so the Matte Varnish application is covering a uniform surface. Otherwise you may still see the outline of the transparent portion of the decal after the Matte is applied. A little bit time-consuming, but actually quite easy to do. Link to comment https://bolterandchainsword.com/topic/169150-shiny-shoulder-transfers/#findComment-1997290 Share on other sites More sharing options...
jester262 Posted May 23, 2009 Share Posted May 23, 2009 yea, that's my method too Link to comment https://bolterandchainsword.com/topic/169150-shiny-shoulder-transfers/#findComment-1997744 Share on other sites More sharing options...
lunchb0x Posted May 23, 2009 Share Posted May 23, 2009 i go with put decal on, then press it firmly in place with a paper towel...and then hit it with a matte varnish. Works everytime for me, and I use GW :lol: Link to comment https://bolterandchainsword.com/topic/169150-shiny-shoulder-transfers/#findComment-1998101 Share on other sites More sharing options...
G. A. K. Posted May 24, 2009 Share Posted May 24, 2009 personaly I use the glossy 'ard coat from GW which I paint on with a brush. I like the shiny look on the armor, like they just polished it before going to war! My great company believes its a 'costume to die in' similar to the samurai. For that same reason I paint my models with a lot of gold and silver metal details. G Link to comment https://bolterandchainsword.com/topic/169150-shiny-shoulder-transfers/#findComment-1998592 Share on other sites More sharing options...
Grimfoe Posted May 25, 2009 Share Posted May 25, 2009 Don't be scared to try your hand at painting on the transfers. Being that we're Space Wolves and not smurfs, I think the painted army badges, pack markings and great company markings look better. I don't think I would do it if we were another chapter, but the tribal look you get with a little variance in our markings seems to fit our models. Link to comment https://bolterandchainsword.com/topic/169150-shiny-shoulder-transfers/#findComment-1999373 Share on other sites More sharing options...
