Mordith Posted May 26, 2009 Share Posted May 26, 2009 This is a 2 part question. 1) Power Weapons - The rule in the book says something to the effect that it cuts thru a models armor and does not give the model an armor save. So here is my question: My Space Marine Sargent has a power sword and is attacking a Killa Kan in Close Combat. He hits with the power sword... how does this work? I know with Power Fists you double the strength up to 10 and then roll to see if it glances or penetrates. But there is no mention of what the stats are for power weapons. It does not say anywhere that it doesn't penetrate Vehicles. 2) Assault Phase - In this example we will go SM Vs. Orks again. Group of Boyz Vs. Vanilla SM. Space Marines get charged by the Orks. Both sides have 10 models. SM attack first correct, because of Init? both sides roll in order of Init and both sides loose 3 models. So each has 7, no one needs to roll a LD test. Here is the main question: Do we keep rolling on the Assault until someone wins or do we go to the next persons turn, and on their Assault Phase, we continue the Melee? Link to comment Share on other sites More sharing options...
Hfran Morkai Posted May 26, 2009 Share Posted May 26, 2009 Question 1: No special rules for power weapons against vehicles, just basic strength plus d6. Question 2: Strike in initiative order, if combat drawn then move onto any other assaults/next players turn. Hope that helps! Link to comment Share on other sites More sharing options...
Mordith Posted May 26, 2009 Author Share Posted May 26, 2009 Nice!! Thanks for the fast response! Good, so I was correct in doing it in this way. :rolleyes: Link to comment Share on other sites More sharing options...
Frosty the Pyro Posted May 26, 2009 Share Posted May 26, 2009 Note: the reason the ork boys and space marines attack at the same time is because orks have furous charge, which gives them +1 initive (and +1 strength) when they charge. That is only for the one assult phase they charged in though, subsequent assult phases will have the marines going first (I4 vs I3) Link to comment Share on other sites More sharing options...
Bran Scalphunter Posted May 26, 2009 Share Posted May 26, 2009 Ork Boyz have I2 base, I3 on the charge, Frosty. So even when charged, Marines go first. Nobz on da uvver 'and, they're I3 base, so they'll strike simultaneously as the Marines on the chage. Link to comment Share on other sites More sharing options...
Frosty the Pyro Posted May 27, 2009 Share Posted May 27, 2009 Ork Boyz have I2 base, I3 on the charge, Frosty. So even when charged, Marines go first. Nobz on da uvver 'and, they're I3 base, so they'll strike simultaneously as the Marines on the chage. Your right, I was thinking nobz :P Link to comment Share on other sites More sharing options...
Grey Mage Posted May 27, 2009 Share Posted May 27, 2009 And of course, if they have a powerclaw theyll strike last. Link to comment Share on other sites More sharing options...
