Meaning of rhino rush and LR rush chaoszylla and NM water wa
Rhino rush is put everything in your army in a Rhino transport and bolt up to the enemy line as fast as you can.
LR rush means go out and pay 300+ dollars on 6 tanks and make a wall of AV 14. Put everything in it or behind it and follow Rhino rush rules.
Chaoszilla is two Daemon Princes, a Greater Daemon, 3 Dreadnoughts, and 3 Defilers. Its just high toughness/armor that most army's would not be able to deal with in assaults.
Not sure what NM water is suppose to be.
Rhino spam is the only real effective list. The other ones are just for fun and are either not effective or just too expensive point wise to use.
rhino rush - all of your squads are in rhinos, providing extra mobility and survivability.
LR rush - similar, but you take 3+ landraiders. all that av14 can be difficult to take down, and lets you get the bulk of your troops into their optimal killing range
chaoszilla- you take 2 daemon princes, possibly a greater daemon, and back them up with dreads and/or defilers. Lots of big, nasty things for the opponent to sweat over, and makes it difficult to prioritize his targets effectively.
NM (Noise Marine) water warrior - probably the most 'advanced' build in the chaos codex, and one very difficult for newer players to win with. The army is more reactive (actually, its kinda hard to explain, I recommend reading Silent Requiem's GK tactica found at http://www.bolterandchainsword.com/index.p...howtopic=101214
example NM water list.
2x demon prince with lash
2x8 man NM squads with sonic weapons . no champions. 2 naked rhinos
1x8man NM squad with sonics
2x2 oblits[or 3x2 depending on points played]
`1x3 terminators with meltaguns
1x5 NM squad with blast master.
example LR rush build
2xdemon prince . one with nurgle rot one with warp time ,
2x8man zerker units
2x7 man pm units with 2 melta guns each in rhinos
2 land raiders [zerkers go here].
example rhino[classic chaos list]
2 demon prince
4xsquads in rhinos [8 zerkers , 7 pms with 2 specials , 4 csm squads
2x3 terminators with melta guns
2x2 obliterators
chaoszylla list
2xDP
3xdefilers
2xdreadnought ccw upgrade only
2x6 man csm squad with one special
1x8 demon unit
NM mobile gunners rely on focussing on small parts using bad blast/ord weapons to scare the enemy into spreading apart, and picking it to death. Using transports more or less to block line of sight and tank shock, etc.. (Just noting things not really mentioned)
Rhino build works well, some tactics in my signature (including water warrior things), may want to check some of those out in the tacticas part.
Chaos Zilla involves 2 princes, the Greater Daemon and champs to get him out, defilers before dreadnoughts, most likely depending on points limit. They get melee builds or missile launcher+DCCW and pick frag when he shoots your stuff.. Some prefer to add terminators with a defensive icon to keep the theme, and maybe best using cheap CSM with glory or plague marines.
