Custodian Athiair Posted May 28, 2009 Share Posted May 28, 2009 Just a quick question with hopefully a quick answer do units that have gone to ground obscur line of sight? i ask this becuase i came up with a plan in the new guard codex: Infantry Platoon with 50 Conscirpts and 5 Infantry Squads you set up them with the Conscripts out the front with the Infantry Squads (who Combine Up into a 50 man squad) lining up behind and then the Command squad behind then the entire 'formation' walks up with the Conscripts taking all the hits as they block the line of sight and then when you get the INfantry squad within 12 inches you send the Conscripts to ground and then issue the 'First Rank FIRE, Second Rank FIRE' order and then you unleash 150 shots at BS4 so anyway please answer the question thanks a lot Athiair :D Link to comment Share on other sites More sharing options...
Captain Malachi Posted May 28, 2009 Share Posted May 28, 2009 I don't see anything mentioning line of sight in the section on going to ground on page 24, so as far as I can tell it'd be the same as if they were still acting like normal. The only thing it mentions is that 'you may want to place the models lying down' or something, which would affect line of sight, however I'd imagine you'd have to put them back as standing up when you check it anyway. I've checked page 16 which deals with line of sight, and I can't see anything mentioning it there either. Link to comment Share on other sites More sharing options...
rat of vengence Posted May 29, 2009 Share Posted May 29, 2009 If your opponent lets you get all of them within 12", you deserve to be able to rapid fire them to death. Good luck doing it though... RoV Link to comment Share on other sites More sharing options...
Master Vandor Posted May 29, 2009 Share Posted May 29, 2009 First a question: How do your guard have BS4? If you are thinking of vets then you need to know that they can't combine squads only the base infantry can. Second: the going to ground rules say that when a unit goes to ground you place a marker on that unit (or lie the unit down on its side). This is the same as placing cotton wool on a tank to represent smoke launchers. It has no effect on the game play. It just reminds the players that the unit has a temporary effect on it. You could of course move the conscripts to the side when you want the normal guard to fire but then you lose your fire/melee screen. Also you're going to need an inquisitor lord or something to boost the conscript's leadership or they will flee pretty quickly. Alternatively use conscripts as a screen (not too tight to block LoS) with veterans behind with stealth. The vets will have a 3+ cover save. But then of course you lose the "one squad one order" effect you were going for. Food for thought though ;) Link to comment Share on other sites More sharing options...
Lord Humongous Posted May 29, 2009 Share Posted May 29, 2009 you send the Conscripts to ground and then issue the 'First Rank FIRE, Second Rank FIRE' order and then you unleash 150 shots at BS4 All that shooting would kill one squad, because those 150 shots (being from one unit) all have to go at one target. It might not even do that- 150 bs4 lazgun shots kills 5.5 deathguard. Either way, the whole mess (or at least the conscripts) is getting charged when they finish shooting. Granted, you'll have 50 or 100 attacks, but any competent enemy is gonna charge everything they have. Link to comment Share on other sites More sharing options...
Isiah Posted May 29, 2009 Share Posted May 29, 2009 Let's keep the replies to the question of cover saves and going to ground. Tactics can be discussed elsewhere please. Cheers I Link to comment Share on other sites More sharing options...
