Kek Posted May 29, 2009 Share Posted May 29, 2009 As the Title says i'm looking for inspiration on how to convert some heralds from a normal Daemon Trooper. I've done a search (or 10!!) but am unable to locate any conversions (just comes up with either army lists or other conversions :D) Any help apreciated. Kek Link to comment Share on other sites More sharing options...
Heru Posted May 29, 2009 Share Posted May 29, 2009 This is a good blog to look at. http://www.bolterandchainsword.com/index.p...;blogid=16& There should be a Slaaneshi Daemon Herald conversion somewhere in there. Link to comment Share on other sites More sharing options...
Slayer le Boucher Posted May 30, 2009 Share Posted May 30, 2009 I don't know if this can help you but i made mine with an Infernal Ambassador from the Return of the Gods mini's. http://img90.imageshack.us/img90/2108/img0555le3.th.jpg http://img215.imageshack.us/img215/1306/img0556rn5.th.jpg But if you want to make an Herald form the plastic troops Deamons(depending wich one you want to make...),you simply make the mini a little bit taller by cutting and re-glueing the legs. Add some armor pieces and a little trophy rack and there it goes. Link to comment Share on other sites More sharing options...
Dragonkin Arenis Posted May 31, 2009 Share Posted May 31, 2009 Not exactly a conversion, but possibly some inspiration for a Bloodletter Herald: http://www.forgeworld.co.uk/khornedpandh.htm Good luck Arenis Link to comment Share on other sites More sharing options...
chaplainmikey Posted May 31, 2009 Share Posted May 31, 2009 I've not got the pics available,but a while back i converted a Slaanesh herald by using the larger taloned arms as an extra set of arms on the normal 'Nette model,just like a mini keeper of secrets. Cheers. Link to comment Share on other sites More sharing options...
Graypaint Posted May 31, 2009 Share Posted May 31, 2009 I don't know if this can help you but i made mine with an Infernal Ambassador from the Return of the Gods mini's. http://img90.imageshack.us/img90/2108/img0555le3.th.jpg http://img215.imageshack.us/img215/1306/img0556rn5.th.jpg But if you want to make an Herald form the plastic troops Deamons(depending wich one you want to make...),you simply make the mini a little bit taller by cutting and re-glueing the legs. Add some armor pieces and a little trophy rack and there it goes. Which line of miniatures is this? Link to comment Share on other sites More sharing options...
malika666 Posted June 1, 2009 Share Posted June 1, 2009 Check out the upcoming Daemon by Troll Forged Miniatures. Hive Trygon (a member here) is working on the beast: link. Link to comment Share on other sites More sharing options...
