Daemon Prince: Wings vs. Mark of Nurgle
If you were fielding a Daemon Prince in a 500 Points Army, and had 20 Points to spend on options, would you choose Wings, or Mark of Nurgle, and why? I'm asking this, because I'm considering starting a 500 Points CSM Army, and I have my eye on the Ultraforge Lord of Pestilence (Swaying slightly off topic here!), but I'm not sure whether to purchase Wings for him? I thought that the Mark of Nurgle would be the obvious choice, but as I can't afford both, I need to select one or the other.
Thanks,
Blood Raven :tu:
Then its wings of course. No doubt possible here. A prince without wings is like...well dont know, but its not effective I can tell you that! Really a Deamon prince without wings is not an option. You should always read the Prince entry like: 'winged prine' 130 points. And from there you can start looking at upgrades.
In a normal game, you definitely want the wings.... in 500 points, your opponent is going to be fielding mostly troops, so T6 vs. T5 is a big deal (space marines hit on 6 instead of 5). I would still take the wings, but it isn't an easy decision.
So I would say it depends on what you are fielding him with and what size table you are playing on. If you have a CC-oriented army, you probably want wings, but if you have a more shooty army, you will want to use him to countercharge and wing-free will be OK. You can always run.
Surely you can find 20 points hiding somewhere in your list- even dropping a body is probably worth it to get both nurgle and wings.
Alright, here's an attempt at the list, altered to have Wings and MoN.
Winged Daemon Prince with MoN: 150 Points
Plague Marine Squad: (7) with Meltagun :171
Plague Marine Squad: (7) with Plasmagun :176
Not really sure about it though. Anyway, thanks for your response! It's certainly been of use to me, and has put some new thoughts into my head. Thanks.
Blood Raven ;)
  blood_raven_240 said:
Alternatively,
Plague Marine Squad: (5) with 2x Meltagun: 135
Plague Marine Squad: (5) with 2x Plasma Gun: 145
Rhino: 35
Rhino: 35
500 Exactly.
Thoughts?
I would worry about getting your squads down so low in number. I know everyone is Rhino crazy these days, but in a 500 point game, essentially a Combat Patrol, I'd think that footslogging wouldn't be that bad and that the 4 PMs you are missing would be more pivotal. The rule is 7 PMs = 10 SMs. Also, stay flexible. Make a list that more a troop killer/assaulty (with flamers) and have the models there to switch out depending on who you are facing. That's my two cents.
People always say this without having the maths... Okay, I admit, this is a little unfair since I'm not using any weapons that ignore their FNP, but I want to show people how resilient they are compared to normal Marines against standard infantry weapons.
10 Marines hit with 60 Bolter shots, 30 wound, 10 fail armour save, all dead.
7 Plague Marines hit by 60 Bolter shots, 20 wound, 6.6 fail armour save, 3.3 fail FNP, 3 dead.
It takes 90 basic Marines rapid-firing to put down 7 Plague Marines on average, but this is a void point, since people always fire Plasma and Krak at them.
Yes but that plasma and other nasty things for your Pm's arent there that much at 500 points. And if someone does, orks will beat the crap out of him, so then you are just unlucky with the matchup.
Really I can ensure you that 2x 5 Plague in rhinos can do fine at 500 points. I mean some of that heavy fire should go at your prince too right?
Why would one not take rhinos at 500 points? The board isnt that small. Plague marines have a range of max 24 inch, 12 if walking so someone outshoots you easily. Rhinos still protect you and get you close easily. The more because rhinos are even harder to take out in 500 points along with your prince. (well not really of course, they are still AV11, but their should be less weapons to take them out like I said before, and because of the smaller board you will be earlier there)
Wings always. MoN only if you have points.
For the Rhino debate, aren't we all ignoring the obvious? Take one Rhino, and footslog the other squad! Something like this:
Daemon Prince: Wings - 130pts
6 Plague Marines: 2 Meltaguns, Rhino - 193pts
6 Plague Marines: 2 Plasma Guns - 168pts
This gives you 9 pts to play with. Not sure what to do with that. Maybe swap a meltagun for a flamer and upgrade to a champion in the rhino squad, just for 1 more attack? Maybe there's a 10pt psychic power for the prince? Anyway, you get the idea.
