BassMattJaxx Posted June 3, 2009 Share Posted June 3, 2009 Hey all I've started to redo my Sword Brethren unit since I was unhappy with how my Dark Angel Veteran conversions ended up. So this time round I'm using the Grey Knights. *Note: Stripped the GS off and started again, scroll down past the first several posts. What I'm planning to build are: 1 with Pair of Lightning Claws and Combat shield (will be greenstuff-chained to a gauntlet) 1 with Melta Gun (Converted Incinerator) 7 with BP and Chainsword Posted below is the first bp and chainsword guy I did today. Camera's not the best, but hopefully you get the idea. http://home.people.net.au/~mozzey/SB1.png http://home.people.net.au/~mozzey/SB2.png Fairly simple, just cut the metal arm holding the storm bolter off in about 3-4 places. The bolt pistol arm matched the way his head is facing, which was an added bonus. Will add some purity/crusader seals to his chest to cover up the filing as well. Green stuffed a small loin cloth on the front, don't think I'll go with a full tabard for them, and still not sure weather or not to add an over-the-shoulder cape. Any thoughts? Will update with more conversions soon. Cheers. Link to comment Share on other sites More sharing options...
Dominar_Mortis Posted June 3, 2009 Share Posted June 3, 2009 so far, so good ;) can't wait to see the LC one as for the over the shoulder i have yet to see one that looks good i'd steer clear of that and stick with the tabbards DM Link to comment Share on other sites More sharing options...
BassMattJaxx Posted June 4, 2009 Author Share Posted June 4, 2009 Update 1: Got a new camera today, and did some more work on the first model last night so here's a couple more pic's. Next up will be the LC and Melta models in the next few days or so. I do agree the over the shoulder cape doesn't look quite right, at least for the GW SB models - I did a smaller style for my Marshall which turned out alright. For now I've gone down the Emperor's Champion loincloth style which I think works out pretty well. Cheers. http://home.people.net.au/~mozzey/sb1-1.png http://home.people.net.au/~mozzey/sb2-1.png Link to comment Share on other sites More sharing options...
BassMattJaxx Posted June 6, 2009 Author Share Posted June 6, 2009 Update 2: Built a few more last night and took some pictures this afternoon. Really liking how they're working out so far. 2/3 built and the other 3 are going to require some more work - cut a little too much into one and he's missing most of his left chest :) The incinerator to meltagun is also proving to a tad more difficult than first thought but I'll deal with that. Model 1 (bp & ccw) with some more green stuff to flesh out his front cloth http://home.people.net.au/~mozzey/sb1-3.png Model 2 (bp & ccw) back and front http://home.people.net.au/~mozzey/sb3-1.png http://home.people.net.au/~mozzey/sb3-2.png Model 3 (bp & ccw) back and front http://home.people.net.au/~mozzey/sb4-1.png http://home.people.net.au/~mozzey/sb4-2.png Model 4 (bp & ccw) back and front http://home.people.net.au/~mozzey/sb5-1.png http://home.people.net.au/~mozzey/sb5-2.png Model 5 (bp & ccw) back and front http://home.people.net.au/~mozzey/sb6-1.png http://home.people.net.au/~mozzey/sb6-2.png Model 6 (lightning claws and combat shield) back and front http://home.people.net.au/~mozzey/claws1.png http://home.people.net.au/~mozzey/claws2.png http://home.people.net.au/~mozzey/shield.png and a group shot so far http://home.people.net.au/~mozzey/group1.png There's a few mold lines I've missed in places so a little polish needs to be done before painting. Link to comment Share on other sites More sharing options...
Drudge Dreadnought Posted June 6, 2009 Share Posted June 6, 2009 I like the concept a lot and so far it looks fine from a distance, but i'd say the greenstuff needs to be cleaned up. Its too thick. Link to comment Share on other sites More sharing options...
warp spider Posted June 6, 2009 Share Posted June 6, 2009 try using vasaline on the sculpting tool - it makes the GS a lot more smooth - also buy (or use) a sculpting tool - i can see your fingerprints all over it! other than that, they are great - using GK bodies is genius. Link to comment Share on other sites More sharing options...
BassMattJaxx Posted June 8, 2009 Author Share Posted June 8, 2009 Cheers for the comments and advice, it is appreciated. Did some clean-up on one of the models, let me know what you think. I've trimmed in some areas and rounded off with some sandpaper. It's about the same thickness as the BT tabard's now, while still having that depth. http://home.people.net.au/~mozzey/sb3-4.png http://home.people.net.au/~mozzey/sb3-3.png Link to comment Share on other sites More sharing options...
DarKHaZZ13 Posted June 8, 2009 Share Posted June 8, 2009 still looks abit....flat with GS cloacks, tabbards and capes you need to exagerate the folds grad a SoB model or a techpriest model and use that as a basis failing that there is a tutorial in the librarium Link to comment Share on other sites More sharing options...
MEanBOb Posted June 8, 2009 Share Posted June 8, 2009 For the GS impaired (unfortunately you, at the moment, fall into this category) bits are your friend. Honestly, your GS tabards are awful and seriously take away from the coolness factor of the GK, so let me give you some suggestions. I've made sword brethren in different ways, including using a commander cape along with a company champion loin cloth. You could just use the cape with a normal BT tabard. I've also used assault terminator groin gaurds to bulk out their armor as well as just giving the model a ton of crusader seals. I'll get some pics up later if i can. Link to comment Share on other sites More sharing options...
MEanBOb Posted June 8, 2009 Share Posted June 8, 2009 doulble post Link to comment Share on other sites More sharing options...
BassMattJaxx Posted June 9, 2009 Author Share Posted June 9, 2009 The age old cliche, if at first you don't succeed, try, try again. Did some more research, spent more time on it, did a few practice runs, and here's the result. Haven't done a cloak as yet, but will get there. http://home.people.net.au/~mozzey/sb-n-1-2.png Link to comment Share on other sites More sharing options...
antique_nova Posted June 9, 2009 Share Posted June 9, 2009 just ead the entire thread and i like this vastly improved gs converson of the cloth. keep up the the good work. Link to comment Share on other sites More sharing options...
MEanBOb Posted June 9, 2009 Share Posted June 9, 2009 That is much better! Keep it up. Link to comment Share on other sites More sharing options...
