Kitbash 2nd Company Commander
Trying my hand at power weapons.
For a while, I thought maybe I'd be doing purple PW, but I decided that it'd be just
too much friggin purple
So green it is.
http://i10.photobucket.com/albums/a126/JohnnyK3886/Picture36-1.jpg
Different angle
http://i10.photobucket.com/albums/a126/JohnnyK3886/Picture37.jpg
Up-a-close
http://i10.photobucket.com/albums/a126/JohnnyK3886/Picture39.jpg
Glowy-eye effect picture
http://i10.photobucket.com/albums/a126/JohnnyK3886/Picture38.jpg
https://bolterandchainsword.com/topic/170466-kitbash-2nd-company-commander/
the sword in his right hand is from the "Assault on Black Reach" commander.
Mhm
to get it situated properly just took a little snipping action; I used the right shoulder of the Sergeant, cut it off at the elbow, and then attached the commander's sword bit to it and it became a cohesive right arm.
(Just in case anyone wanted to know)
You COULD just use the sergeant arm, but then he'dve had a powersword and chainsword, and that would look
well
lame
I suggest painting the rim of the base, black or dark brown for added contrast.
I've never messed with the sides of my bases before. (Just paint them like the tops)
What kind of dark brown recipe do you recommend?
Any, I personally just go with black. Doesn't detract from the model and doesn't clash either. What you end up with is the model, the scenic stuff on top of the base, and a void that doesn't drag attention away from the other two.
What I notice about your model there is that the base's green edge / rim seems to take away some of the focus of the swords' green.
Yeah, sure.
The body is the metal Veteran (pose 1, I think?) with a powersword from the Commander box set, the right shoulder of the Sarge from AoBR, the right-hand sword of the Commander from AoBR, and the commander backpack from AoBR.
The Heraldry shield on his stomach is off an AoBR termie - but you can find those on bits shops now, too, to avoid having to do all the snip-snip.
The little eagle decal on his left shoulder is one of the blingcessories from the Commander's box set...
...aaaaand that's that.
:drool:
