Dusktiger Posted June 13, 2009 Share Posted June 13, 2009 so this is my first mini that i've tried highlighting. it was done with a basecoat of knarloc green over a previously painted mini, then i did reaper Brilliant Green over that, and highlighted with Viper Green. the shoulders and calves are Reaper Adamantium Black, and the 5th company trim is thamar black Link to comment Share on other sites More sharing options...
Kable Posted June 14, 2009 Share Posted June 14, 2009 For a first attempt at highlighting that's pretty good! I remember my first try at it and your first go puts mine to shame. The only advice i can offer you i guess for now is to practice. The more your practice the better you will become as with all aspects of the hobby. Link to comment Share on other sites More sharing options...
Arch«•»Angel Posted June 14, 2009 Share Posted June 14, 2009 working on highlights, the first thing i would recommend you to work on are thinner lines. otherwise, pretty good for a first try though. hope to see more Link to comment Share on other sites More sharing options...
chris-kirky Posted June 14, 2009 Share Posted June 14, 2009 ye you definately need to thin down your highlights alot. also make sure that you still water down your paints as normal. The highlight is a bit bright compared to the base coat so try to get more of a mid-tone between the two colours. keep practicing and you will be a pro in no time :) Link to comment Share on other sites More sharing options...
