azoth Posted June 19, 2009 Share Posted June 19, 2009 is the multi melta that you can take as an option for the redeemer pintle mounted or is it counted as another turret? thank you for your responces, Azoth Link to comment https://bolterandchainsword.com/topic/171484-land-raider-reddemer-multi-melta/ Share on other sites More sharing options...
Banville Posted June 19, 2009 Share Posted June 19, 2009 Not that it makes a difference, it's mounted on a pintle. It still counts towards the weaponry on the tank and Power of the Machine Spirit can fire it. Link to comment https://bolterandchainsword.com/topic/171484-land-raider-reddemer-multi-melta/#findComment-2026713 Share on other sites More sharing options...
azoth Posted June 19, 2009 Author Share Posted June 19, 2009 i was wondering cause i thought pintle mounted weapons could use the aa rule Link to comment https://bolterandchainsword.com/topic/171484-land-raider-reddemer-multi-melta/#findComment-2026738 Share on other sites More sharing options...
Isiah Posted June 19, 2009 Share Posted June 19, 2009 i was wondering cause i thought pintle mounted weapons could use the aa rule You are right. All pintle-mounted weapons do indeed have the anti-aircraft mount rule. Cheers I Link to comment https://bolterandchainsword.com/topic/171484-land-raider-reddemer-multi-melta/#findComment-2026756 Share on other sites More sharing options...
azoth Posted June 20, 2009 Author Share Posted June 20, 2009 so to clarify the multimelta on a landraider redeemer can use the aa rule? Link to comment https://bolterandchainsword.com/topic/171484-land-raider-reddemer-multi-melta/#findComment-2026768 Share on other sites More sharing options...
angry man Posted June 20, 2009 Share Posted June 20, 2009 yes. indeed. certainly. affirmative. confirmed. the MM on a LR can use the AA rule as it is a pintle mounted weapon Link to comment https://bolterandchainsword.com/topic/171484-land-raider-reddemer-multi-melta/#findComment-2026930 Share on other sites More sharing options...
azoth Posted June 20, 2009 Author Share Posted June 20, 2009 thank you for all of your replys, azoth Link to comment https://bolterandchainsword.com/topic/171484-land-raider-reddemer-multi-melta/#findComment-2027102 Share on other sites More sharing options...
