iceman kw Posted June 26, 2009 Share Posted June 26, 2009 hi there i'm new to this site and to the game so i'm not sure if i'm posting in the right section, if i am i'm very sorry about it. So i have started playing recently and have decided to play space wolves and i enjoy playing the game and always enjoyed watching games but the problem i'm having right now is how to set up my own army list. A friend is telling me to use both SW codex and SM codex in ways i don't understand. basicly i'm confused and don't know which points to use for each pack or for anything. any help will be gratly appriciated as i can't not wait to fight a real battle. thanks for reading and any help you give. iceman kw out. Link to comment https://bolterandchainsword.com/topic/171930-sw-army-help/ Share on other sites More sharing options...
Banville Posted June 26, 2009 Share Posted June 26, 2009 You should probably post this in the Space Wolf Sub Forum but I'll give you a bit of advice. Firstly get your Space Wolf Codex and your Space Marine Codex. You need both because some of the SW wargear rules are to be found in Codex: Space Marines. Now, determine how many points of an army you want and pick up your SW Codex. Next find yourself a HQ unit you like the look of and add the wargear you'd like him to have. Fourthly get yourself 2 Troop choices and equip as you see fit. Fifthly just mix and match from the rest of the SW Codex until your points total is filled The Codexes (Codici?) are structured so that you buy a unit at a base points cost and then add the equipment that you purchase on to this. Link to comment https://bolterandchainsword.com/topic/171930-sw-army-help/#findComment-2032107 Share on other sites More sharing options...
Bran Scalphunter Posted June 26, 2009 Share Posted June 26, 2009 Welcome to the Fang (an early greeting I know), and as your friendly neighborhood Space Wolf, I'll help you out. First off, do you have both the current SW codex and SM codex? Second, do you have the FAQ/Erratas from the GW website? Now a basic layout of how our funky rules work. Space Wolves use a different Force Organization Chart (FOC) than other armies by having to take more HQ choices. For every 750pts of the army list, an HQ must be selected from the C:SW. These are mandatory and have to be taken in order to have a legal list. Units that are taken from C:SM are vehicles and all C:SM variants (unless described differently in C:SW {Leman Russ Exterminator and Space Wolf Venerable Dreadnought}). In addition, Attack Bikes are taken from C:SM. However, any unit taken from C:SM will not use C:SM rules, it will instead use the C:SW rules. Certain special rules in our Codex are older and have newer versions in the Big Rule Book (BRB), like Counter-Attack for example. As per the GW FAQ, we use the current Counter-Attack from the BRB. However, True Grit is not listed in the BRB, so it is used as in C:SW. Other rules, like No Matter the Odds, are now defunct and are ignored. If there's anything else you need, just head over to the SW forum and if you need rules help, check the links in my signature- they'll bring you to the GW and B&C SW FAQ's respectively. Link to comment https://bolterandchainsword.com/topic/171930-sw-army-help/#findComment-2032143 Share on other sites More sharing options...
Legatus Posted June 26, 2009 Share Posted June 26, 2009 At the time the Codex Space Wolves was released (many, many years ago) it was GW's custom that all Space Marine Chapters would be based off of Codex Space Marines, but the more divergent Chapters like Blood Angels, Dark Angels and Space Wolves got "Update Codices", books which basically explained in what way those Chapters would be different from a Codex Space Marines army. The Codex Space Wolves tells you what units and vehicles you can chose for your Space Wolves army, and often they are very different from the units a regular Chapter would use, so the Codex Space Wolves has all the unit information like points costs, game stats and upgrade options. Some vehicles and items are the same that other Chapters use, though, and those can be found in Codex Space Marines, so the Codex Space Wolves does not describe them and only refers to Codex Space Marines, since all the standard stuff is described in there. Since the Codex Space Wolves has been released, there have been two new versions of the Codex Space Marines, so you may be confused that some point costs in your Codex Space Wolves (like for Predator tanks) or some Item Descriptions (like Storm Shields with a 4+ invulnerable save in the summary) do not match the current Codex Space Marines. There have been two new basic rule systems since then as well, and though the Codex is still compatible, some rules in the Codex do refer to outdated game mechanics. The Space Wolves FaQ has some information on some of the rules and unit descriptions that are outdated. The current Codex Space Wolves is quite old, and though you might still want to get it to start playing or for reference, it is rumoured that a new Codex Space Wolves will be released in October or so. That Codex will stand on it's own, and will not rely on Codex Space Marines. It will probably have a lot more background information as well. Link to comment https://bolterandchainsword.com/topic/171930-sw-army-help/#findComment-2032150 Share on other sites More sharing options...
Prathios Posted June 26, 2009 Share Posted June 26, 2009 The most important piece of advice I can give you is to make sure as a new SW player to keep Bran happy... He has this thing called an exterminatusock and he knows how to use it... Link to comment https://bolterandchainsword.com/topic/171930-sw-army-help/#findComment-2032178 Share on other sites More sharing options...
Bran Scalphunter Posted June 26, 2009 Share Posted June 26, 2009 The most important piece of advice I can give you is to make sure as a new SW player to keep Bran happy... He has this thing called an exterminatusock and he knows how to use it... Yep! :) And don't forget Dark Bjorn, he's got the Ragnaroksock too! But don't worry, I only use the ES on people who deserve it. Or those that steal my ale :) Link to comment https://bolterandchainsword.com/topic/171930-sw-army-help/#findComment-2032190 Share on other sites More sharing options...
Dark Bjoern Posted June 26, 2009 Share Posted June 26, 2009 What??!! Someone here who needs a small thought-provoking impulse with the Ragnaroksock???!!!! http://i186.photobucket.com/albums/x120/DarkBjoern/Ragnarksock.jpg Oh, a new whelp. Welcome to the Fang. Link to comment https://bolterandchainsword.com/topic/171930-sw-army-help/#findComment-2032232 Share on other sites More sharing options...
Warhorse47 Posted June 26, 2009 Share Posted June 26, 2009 Welcome to the Fang! Gray Hunters, Rhinos and Blood Claws are the basic building blocks here. And don't mind the ork behind the counter, he makes the hot wings...... Link to comment https://bolterandchainsword.com/topic/171930-sw-army-help/#findComment-2032267 Share on other sites More sharing options...
Bran Scalphunter Posted June 26, 2009 Share Posted June 26, 2009 Welcome to the Fang! Gray Hunters, Rhinos and Blood Claws are the basic building blocks here. And don't mind the ork behind the counter, he makes the hot wings...... Yer, jus don't ask where da wingz come frum an yer good. An don't fergit ter post all yer Space Wuff stuff 'ere, cuz dis iz da most proppa forum on da 'ol Blasta&Choppa... urmm, Bolter & Chainsword I mean. :teehee: Link to comment https://bolterandchainsword.com/topic/171930-sw-army-help/#findComment-2032290 Share on other sites More sharing options...
iceman kw Posted June 26, 2009 Author Share Posted June 26, 2009 thank you all very much been a great help and for the warm welcome. yes bran i have both codexs so no worries there. just one more quick question but what points would i use for each unit ??? this is by far the thing that's confusing me the most??? i have an idea is it that i use a chapter master points for a wolf lord and then dive into the SW armory and if so what points sould i look at for each unit ??? thanks again wolf bretheren...probaly spelled wrong but i'm not know well for my spelling :lol: :lol: :lol: Link to comment https://bolterandchainsword.com/topic/171930-sw-army-help/#findComment-2032339 Share on other sites More sharing options...
Legatus Posted June 26, 2009 Share Posted June 26, 2009 Units that are described in the Codex Space Wolves in detail are bought from and use the rules described in the Codex Space Wolves. Units that are not listed as being available in Codex Space Wolves cannot be taken in a Space Wolves army. i.e. Space Wolves armies cannot include Chapter Masters or Sternguard Veterans from Codex Space Marines. But they use Land Speeders, Attack Bikes and Predators from Codex Space Marines. All Space Wolve Specific units have their own point costs in the Codex Space Wolves. Link to comment https://bolterandchainsword.com/topic/171930-sw-army-help/#findComment-2032369 Share on other sites More sharing options...
Grey Mage Posted June 26, 2009 Share Posted June 26, 2009 hi there i'm new to this site and to the game so i'm not sure if i'm posting in the right section, if i am i'm very sorry about it. So i have started playing recently and have decided to play space wolves and i enjoy playing the game and always enjoyed watching games but the problem i'm having right now is how to set up my own army list. A friend is telling me to use both SW codex and SM codex in ways i don't understand. basicly i'm confused and don't know which points to use for each pack or for anything. any help will be gratly appriciated as i can't not wait to fight a real battle. thanks for reading and any help you give. iceman kw out. Ok... so is the unit you want to pick detailed in the Space Wolf codex? If yes: use all the point values and stats in the unit entry as normal. If not: look in Codex Space marine, use the stats shown there. Are you trying to buy a dedicated transport? If so- go to the transport section of codex space marine. Are you trying to buy a vehicle other than a venerable dreadnaught or a leman russ exterminator? if so- go to codex space marine. Are you trying to buy a venerable dreadnaught or leman russ exterminator- if so go to codex space wolf and use all the point values shown there, and in the vehicle section of the armory. Are you looking for the stats of a weapon other than a frostblade? If so look in codex space marine. Are you looking for the rules for wargear not outlined on page 14 of the codex? if so, then follow the instructions at the top of the page and look in C:SM. Link to comment https://bolterandchainsword.com/topic/171930-sw-army-help/#findComment-2032419 Share on other sites More sharing options...
iceman kw Posted June 26, 2009 Author Share Posted June 26, 2009 ok i got yeah now thanks, now to start writing up some lists. thanks again to all. Link to comment https://bolterandchainsword.com/topic/171930-sw-army-help/#findComment-2032426 Share on other sites More sharing options...
Rokafort Stonewolf Posted June 27, 2009 Share Posted June 27, 2009 Welcome to the Fang, glad you figured it out. I guess compared to 5th edition books it IS a bit messy. Link to comment https://bolterandchainsword.com/topic/171930-sw-army-help/#findComment-2032606 Share on other sites More sharing options...
iceman kw Posted June 27, 2009 Author Share Posted June 27, 2009 i know like i've been running around for the past week buying wolf lords for about 125 points...i thought something was very wrong there. Link to comment https://bolterandchainsword.com/topic/171930-sw-army-help/#findComment-2032716 Share on other sites More sharing options...
