joeshmoe Posted July 6, 2009 Share Posted July 6, 2009 Do Radpid fire rules apply to Hurricane Bolters on LRC's?...one shot at 24inch / 2 shot at 12inch? Does movement of the LRC effect this? Also, I want to run my Rhino's with 2 storm bolters. Can I fire both (since they are both strength 4 defensive weapons) if i move 12inches? Thanks much. Link to comment Share on other sites More sharing options...
jeffersonian000 Posted July 6, 2009 Share Posted July 6, 2009 Yes to the first two questions, No on the third (you cannot fire any weapons on a Rhino if it moves more the 6"). SJ Link to comment Share on other sites More sharing options...
Mycroft Holmes Posted July 6, 2009 Share Posted July 6, 2009 Yes to the first two questionsSJ Almost. BRB pg 58 "In addition, the normal penalties of movement on shooting rapid fire and heavy weapons do not apply - when fired from a vehicle, these weapon types always fire as if the firing model had not moved, regardless of whether it actually did or not." Mycroft Link to comment Share on other sites More sharing options...
Bonham1963 Posted July 6, 2009 Share Posted July 6, 2009 Still couldn't fire if it moved at cruising speed, regardless of weapon type. Link to comment Share on other sites More sharing options...
joeshmoe Posted July 6, 2009 Author Share Posted July 6, 2009 thanks you guys for clearing these up. Link to comment Share on other sites More sharing options...
Mycroft Holmes Posted July 6, 2009 Share Posted July 6, 2009 Still couldn't fire if it moved at cruising speed, regardless of weapon type. Yes, that is true; but he didn't ask that. He asked about shooting defensive weapons on a cruising speed rhino. I was correcting the error in the first response; he needs to know that the speed of vehicle doesn't affect his ability to fire at full range with Rapid Fire weapons. Mycroft Link to comment Share on other sites More sharing options...
nighthawks Posted July 6, 2009 Share Posted July 6, 2009 Yes to the first two questionsSJ Almost. BRB pg 58 "In addition, the normal penalties of movement on shooting rapid fire and heavy weapons do not apply - when fired from a vehicle, these weapon types always fire as if the firing model had not moved, regardless of whether it actually did or not." Mycroft note that this quote relates to the use of the hurricane bolters - they still are rapid fire, but as they are mounted on a vehicle may be fired at full range even if it moved. the bullets above this quote (left column, page 58) say that a vehicle that moves at cruising speed may not fire weapons. 12" is cruising speed (>6in) so no weapons. if the rhino moves 6in or less, then both storm bolters may fire. Link to comment Share on other sites More sharing options...
Bran Scalphunter Posted July 6, 2009 Share Posted July 6, 2009 And just to make things clear, if you are using a BA Rhino and pass the Overcharged roll, then you can fire your defensive weapons (Yay Fast Rhinos!). Link to comment Share on other sites More sharing options...
Souchan Posted July 6, 2009 Share Posted July 6, 2009 Then in come GK land raider crusaders, who make things even more confusing by working entirely different^^ Link to comment Share on other sites More sharing options...
