igotsmeakabob!! Posted July 6, 2009 Share Posted July 6, 2009 So, quick question. If an Independent Character begins the game with a unit of Space Marine scouts, can he infiltrate and move using Scouts with them? I'm guessing not, unless the IC himself has the Scouts and Infiltrator rules... but I just need some validation here. edit: Some page citations would help too. Link to comment Share on other sites More sharing options...
Ideaus Posted July 6, 2009 Share Posted July 6, 2009 no as you said he need the infiltrator/scout rule himself or teh unit will lose the ability, pg 48 of the BRB under heading special rules. "when an IC joins a unit it might have a different special rule to the unit. Unless specified in teh rule itselfs, the unit's special rules do not conferred upon the character and the character spec rule do not transfer to the unit" and infiltrator is one specificaly mentioned that does not confer. hope that helps Link to comment Share on other sites More sharing options...
Legatus Posted July 6, 2009 Share Posted July 6, 2009 You could also go to page 74 and 75, where the universal Special rules are explained. Among those rules is "infiltrate", and it is marked with an asterisk (*), which, as page 74 explains, means that this special rule is lost if a character joins a unit and either one does not has that special rule. Link to comment Share on other sites More sharing options...
igotsmeakabob!! Posted July 6, 2009 Author Share Posted July 6, 2009 Thanks alot. Link to comment Share on other sites More sharing options...
