iceman kw Posted July 8, 2009 Share Posted July 8, 2009 can wolf guaed bodyguard take frost blades or axes ??? Link to comment https://bolterandchainsword.com/topic/172943-wolf-guard-question/ Share on other sites More sharing options...
muzzyman1981 Posted July 8, 2009 Share Posted July 8, 2009 Are there points values in the Wolf Guard wargear column? Link to comment https://bolterandchainsword.com/topic/172943-wolf-guard-question/#findComment-2044312 Share on other sites More sharing options...
iceman kw Posted July 8, 2009 Author Share Posted July 8, 2009 no Link to comment https://bolterandchainsword.com/topic/172943-wolf-guard-question/#findComment-2044323 Share on other sites More sharing options...
muzzyman1981 Posted July 8, 2009 Share Posted July 8, 2009 Then you cannot take them for Wolf Guard. Frost Weapons are usually reserved for higher ranking Wolves (fluff-wise) I had to make sure you weren't just trying to get free codex info without having the codex =) Link to comment https://bolterandchainsword.com/topic/172943-wolf-guard-question/#findComment-2044327 Share on other sites More sharing options...
iceman kw Posted July 8, 2009 Author Share Posted July 8, 2009 oh no don't worry i have the dex just wondering because it said na(what does that mean By The Way) but thanks anyway, big help. Link to comment https://bolterandchainsword.com/topic/172943-wolf-guard-question/#findComment-2044334 Share on other sites More sharing options...
muzzyman1981 Posted July 8, 2009 Share Posted July 8, 2009 na - N/A - Not Available i.e. cannot be taken Link to comment https://bolterandchainsword.com/topic/172943-wolf-guard-question/#findComment-2044335 Share on other sites More sharing options...
iceman kw Posted July 8, 2009 Author Share Posted July 8, 2009 ok kool thanks Link to comment https://bolterandchainsword.com/topic/172943-wolf-guard-question/#findComment-2044341 Share on other sites More sharing options...
Grey Mage Posted July 9, 2009 Share Posted July 9, 2009 While were on the subject of Wolf Gaurd and IC equipment note that an Iron Priest has to take the more expensive wargear and that a Wolf Gaurd Battle Leader does too- and has access to heavy weapons via the part of his entry that says he can take equipment from the wolf gaurd entry. Link to comment https://bolterandchainsword.com/topic/172943-wolf-guard-question/#findComment-2044431 Share on other sites More sharing options...
Jaarl Stormfang Posted July 9, 2009 Share Posted July 9, 2009 Technically N/A really means not applicible. It's used when there would be information, or information to be filled in, but for some reason or other it wouldn't be relevant. Such as gender: man. Bra size: N/A :) In this case, points aren't listed, because the weapons can't be taken so there is no point size applicable. Just like a bra size wouldn't be applicable to a man. (hopefully) Link to comment https://bolterandchainsword.com/topic/172943-wolf-guard-question/#findComment-2045457 Share on other sites More sharing options...
