Legacy40k Posted July 17, 2009 Share Posted July 17, 2009 After much searching, I wasn't really able to find any threads on how to make a combi melta or a heavy flamer that I actually liked the looks of. So.. i decided to make my own up and show them with you. The Combi Melta is made from a Bolter, a melta gun nozzel, and a little bit of plastic tubing attached to the end with a hole drilled in each side. Of course the orriginal barrel had to be removed first. http://img.photobucket.com/albums/v241/Legacy40k/Space%20Marines/DSCF1766.jpg http://img.photobucket.com/albums/v241/Legacy40k/Space%20Marines/DSCF1767.jpg The Heavy flamer was made from a space marine bolt pistol arm, a Catachan heavy flamer, a Cadian flamer backpack attached to a slightly modified marine backpack, some wire, some greenstuff and some Greebles. http://img.photobucket.com/albums/v241/Legacy40k/Space%20Marines/DSCF1768.jpg http://img.photobucket.com/albums/v241/Legacy40k/Space%20Marines/DSCF1769.jpg http://img.photobucket.com/albums/v241/Legacy40k/Space%20Marines/DSCF1770.jpg Link to comment Share on other sites More sharing options...
glayvin34 Posted July 17, 2009 Share Posted July 17, 2009 Very impressive. I really like the heavy flamer, I'm going to have to make one for my Salamander Sternguard. The HF is the obviously tactical choice for the ST, most folks like to keep them on the move and keep infantry away. The HF is good for both of those roles. One question, though, is "Greebles" your word for bits? Link to comment Share on other sites More sharing options...
Legacy40k Posted July 17, 2009 Author Share Posted July 17, 2009 One question, though, is "Greebles" your word for bits? Greeble: "A greeble or nurnie is a small piece of detailing added to break up the surface of an object to add visual interest to a surface or object, particularly in movie special effects. They serve no real purpose other than to add complexity to the object, and cause the flow of the eye over the surface of the object to be interrupted, usually giving the impression of increased size. It is essentially the small detailed technical part of a larger object. The detail can be made from geometric primitives, including cylinders, cubes, and rectangles, combined to create intricate, but meaningless, surface detail. Greebles are commonly found on models or drawings of fictional spacecraft in science fiction." It's my favorite new word, and I've been looking for an excuse to use it :D Link to comment Share on other sites More sharing options...
yodaid764 Posted July 18, 2009 Share Posted July 18, 2009 I actually took at Chaos Terminator Heavy Flamer, chopped off the arm just below the elbow, shaved off the Chaos arrows and the demonic skull on the top, attached it to an arm that is stuck out straight, then glued on a back pack from a plasma cannon devestator. It will need some green stuff to attach the cables to the HF but I like the look of the model so far. Throw on some purity seals and other bitz from the SM commander pack and I have my newest Sternguard.I tried to take a pic but they all come out blurry. Link to comment Share on other sites More sharing options...
JMcL63 Posted July 18, 2009 Share Posted July 18, 2009 'Greebles'! What a great word. I've knowingly used greebles without knowing they were 'greebles', if you get my drift. Now my greebles will be more greebly than ever! Thanks for that Legacy40k. :P Link to comment Share on other sites More sharing options...
Battle Captin Torodin Posted July 18, 2009 Share Posted July 18, 2009 I've recently made a stergaurd with heavy flamer, was a very simple conversion. i cut down the end of a multi melta and put a dread heavy flamer on it, then using the melta back pack i put it all on the sternguard with no arms. will add a picture soon Link to comment Share on other sites More sharing options...
