gmsniper Posted July 28, 2009 Share Posted July 28, 2009 Can an IC that is in retinue form join another squad? I want to say the answer is no because he is no longer an IC. I wish I could bring my codecies and BRB to work lol. Alternatively other ICs could join the retinue freely? Thanks- Greg Link to comment Share on other sites More sharing options...
Grey Mage Posted July 28, 2009 Share Posted July 28, 2009 An IC cannot join more than one squad at a time... so in general... no. There are a couple of times this isnt the case... but its where they buy the retinue as wargear- like tau gundrones and a commander, or space wolf HQs with fenrisian wolves. Other ICs can join another characters retinue. BT have a few odd rules on this, but in general you can join any characters retinue youd like. The newly attached IC doesnt gain the benefit of being in a retinue however. Link to comment Share on other sites More sharing options...
gmsniper Posted July 28, 2009 Author Share Posted July 28, 2009 Thanks for the answer now that I have my scenario set up I have another question How would wound allocation be worked out if I had this example Grey Knight BC with retinue, and SM commander, and a Librarian? For assualt it would be whomever is in BTB and the attacks are directed against? is that correct. For shooting I am slightly confused on how to work it out. Since I have single wound and multiple wound models who has to take the wounds first? Link to comment Share on other sites More sharing options...
Frosty the Pyro Posted July 28, 2009 Share Posted July 28, 2009 use regulare wound allocatoin for shooting. AKA roll to hit, roll to wound, assighn wounds to models (remember every model has to have one wound before you can put a second wound on anything.), group like models, roll armor saves. In your example for close combat, the comander and libriarian will count as seperate targets, anyone in btb with them may attack them directly. The grey knight and retinue will count as single target and you will alocate wounds as normal in shooting. Link to comment Share on other sites More sharing options...
gmsniper Posted July 28, 2009 Author Share Posted July 28, 2009 Don't you have to remove whole models before spreading the wounds around as per page 26 of the BRB Link to comment Share on other sites More sharing options...
SeattleDV8 Posted July 28, 2009 Share Posted July 28, 2009 The rules on pg.26 are for units of multiple wound models, such as Nobs and Orgyns. A unit with a single IC (even 2 or more) do not use those rules. Link to comment Share on other sites More sharing options...
Frosty the Pyro Posted July 29, 2009 Share Posted July 29, 2009 Don't you have to remove whole models before spreading the wounds around as per page 26 of the BRB The rules on pg.26 are for units of multiple wound models, such as Nobs and Orgyns.A unit with a single IC (even 2 or more) do not use those rules. You are both right and wrong. Wound allocation happens before removing models, ala page 25 "complex units". Note on pg 26 it says "if the unit consists of different models, first allocate the wounds suffered. Then take saves for identical models at the same time as normal" So First you allocate wounds, every model must be assighned one wound before any model can hace a second, every model must have two wounds befor any model can have a third and so on. Then you divide the models into groups of identical models and roll your saves. Once in these identical groups then you are required to remove whole models whenever able. Link to comment Share on other sites More sharing options...
gmsniper Posted July 29, 2009 Author Share Posted July 29, 2009 That actually works out better than I thought it would. I still see alot of arguing over this when the time comes, but at least I have some evidence to back up my claims. Thanks Link to comment Share on other sites More sharing options...
nighthawks Posted July 31, 2009 Share Posted July 31, 2009 it's harder to explain to some than to others - I guess we all think a bit differently. at any rate, once you have it sorted, it works well, and leads to a lot of optioned-out units to increase the uniqueness of the individual members / breakup save groups. good mechanic and a lot easier to use than the previous mixed armour rules. Link to comment Share on other sites More sharing options...
