Power Fist or Melta Bombs?
I've been thinking lately, that instead of putting a Power Fist in every squad, wouldn't it be better to save twenty points and get Melta Bombs?
Pro Power Fist:
- More Attacks
- Power Weapon*
Power Fist Cons:
- Costs more than most CSM Troops.
- Initiative Penalty
Pro Melta Bomb:
- Same Strength as power fist.
- Lower cost compared to power fist.
Melta Bomb Cons:
- Not a power weapon.*
- Only one attack against vehicles.
*Note that you could get them a power weapon for 15 points and still be saving 5 points over a power fist.
It seems to me that with the exception of monstrous creatures, that getting melta bombs is a better use of points. Thoughts?
https://bolterandchainsword.com/topic/175444-power-fist-or-melta-bombs/
IIRC you can only use melta bombs on vehicles not troops, etc, so another con for bombs...
right now the only model i use with bombs is a CSM lord with wings, power weapon, and icon... kinda backs up where
i need him and gets demons/termies on the board as well
Grim
Power Fists are better in almost every situation you can imagine.
They squish MCs
They smash Dreadnoughts (remember you have to roll a 6 with 1 attack to Melta Bomb a Dread)
They have multiple attacks against AV10 rear armor which is often better than 1 Meltabomb.
They can be used against infantry unlike Grenades
Plus your basic infantry come standard with Krak Grenades, which is enough to destroy most armor and atleast threaten a Dreadnought.
The one time a Meltabomb is worthwhile is trying to assault AV14, where you can only glance it with a Power Fist. Of course if you just brought a Melta-Gun along, you could do the same thing but better.
Put another way, the Meltabomb is a backup weapon if you feel the urge to take a Power Weapon instead of a Power Fist (like your playing Noise Marines or something).
Meltabombs belong on HQ's that dont often pack powerfists. Aside from the random I5 champ with IoS/MoS that uses a power weapon with meltabombs costing 5 pts less then a powerfist when combined.
Fist on everything else normally, I would take one less model if it meant giving a powerfist to my champion instead of a power weapon. In one case for a 1750 deceleration league where starting with 2k and removing 250 pts for every fight (second level) I removed a marine that made sure I couldnt have a second meltagun just to keep that powerfist.
Remember, the fist provides at least 50% of the squads killing power. Power Weapon is nowhere near that. A power weapon champ doesn't even average 1 kill vs meqs. A fist does. And it threatens everything.
Its not quite that bad when comparing it just against MEQs.
On the charge a Power Fist averages 1.25 dead MEQs whereas a Power Weapons averages 1.0.
In combat its 0.83 vs 0.75 respectively.
So against just MEQs you're trading a slight increase in killing power against striking at I1.
Its all the other stuff that can assault you that really makes the Power Fist worthwhile.
To the OP: I just created a thread a few days ago about when its appropriate to use a Power Weapon. Long story short, its only better then a Power Fist in very select situations.
Melta Bomb Cons:
Meltabomb cons:
does nothing v MC's or anything but vehicles
1 chance to hit vehicles that moverd 6" on 4+, if vehicle moved more then 6" then 1 chance to hit only on 6. At least a PF gets 3 chances.
But really, relying on PF to take out vehicles is a poor plan, really you should have plenty of meltas and hvy weops for that.
