Help Please
Ragner Blackmane
I wasn't sure if this should be posted here or in the army lists section so if it's wrong then sorry.
Anyway I have a battle coming up against Imperial Guard, 1500pts. And I have seen his army before and think it would help to get guidance from my fellow Brothers.
So I hope you can assist me on making my army and then I will pt the army list when you hae given me guidance.
THANKS :D
https://bolterandchainsword.com/topic/176066-help-please/
It would also help to know what models and units you have available to choose from for creating your army. There really isn't much point in fellow Wolves making recommendations for an army comprised of units that you don't have.
Valerian
https://bolterandchainsword.com/topic/176066-help-please/#findComment-2080848
If he only has 3 tanks Whirlwinds are a great option, pretty much killer vs anything else he can field. OBEL scouts with a melta and a couple of plasmas will worry his tanks. If he has a couple of basilisks you'll definitely want either drop pods or rhinos for your troops, with luck (your bad/his good) he could wipe out whole squads easily if you leave them in the open. I think they have a min range of 36" though, so try and close into that range ASAP.
Heavy Flamer/Heavy Bolter Land Speeders will also cause him some stress.
https://bolterandchainsword.com/topic/176066-help-please/#findComment-2080905
If you have the model, or the time to get it, I think scouts in a Land Speeder Storm might be an option as well. Outfit the scouts with a melta gun, plasma pistols and melta bombs. Give the storm a multi-melta or an assault cannon. You speed across the board and disembark and fire on two tanks. With luck, you could destroy both.
https://bolterandchainsword.com/topic/176066-help-please/#findComment-2080908
I would also add that the more dakka that you have on your vehicles/dreads the better. twin, twin autocannons would be nice for the baskis and troops. long fangs with tank busta, and AP weapons (two las a missile and a HB) i give each of my packs a melta, or a flamer just for flexibility
https://bolterandchainsword.com/topic/176066-help-please/#findComment-2081362
