Illestsaini Posted August 18, 2009 Share Posted August 18, 2009 If your in a Chaos Rhino, can you use Lash of Submission while inside of it with your Sorcerer, Thank you Link to comment Share on other sites More sharing options...
Seahawk Posted August 18, 2009 Share Posted August 18, 2009 Of course you can. You measure the range and LOS from the edges of the top hatch. Link to comment Share on other sites More sharing options...
Azulz Posted August 18, 2009 Share Posted August 18, 2009 Of course you can. You measure the range and LOS from the edges of the top hatch. what about if the vehicle has no firing points? Can you still cast? I would think you would have to have firing points.. doesnt the land raider have no points to fire from? Link to comment Share on other sites More sharing options...
nighthawks Posted August 18, 2009 Share Posted August 18, 2009 if you need LOS, then you need fire points. you are correct, there are none on the land raider. Link to comment Share on other sites More sharing options...
Seahawk Posted August 18, 2009 Share Posted August 18, 2009 You originally asked only about a rhino :P, but yes you need to have a firepoint for Lash, and since there are none on a land raider, no lashing. Link to comment Share on other sites More sharing options...
