Redbaron997 Posted August 19, 2009 Share Posted August 19, 2009 How far can a vehicle move and the squad embark. For example can a Wave serpant move flat out (24in) and the squad get out and shoot? Thanks a bunch. Link to comment Share on other sites More sharing options...
DarkGuard Posted August 19, 2009 Share Posted August 19, 2009 5th Ed 40K Rulebook, page 70, bottom of 2nd column: Passengers may not embark onto or disembark from a fast vehicle if it has moved (or is going to move) flat out in that movement phase. So no you can't disembark from a Falcon that has moved flat out. You can if it was stationary or moved at combat or cruising speed. Link to comment Share on other sites More sharing options...
Frosty the Pyro Posted August 19, 2009 Share Posted August 19, 2009 Pg 67 of the main rule book Edit pg 70 if also fast. Link to comment Share on other sites More sharing options...
Redbaron997 Posted August 19, 2009 Author Share Posted August 19, 2009 So you can only ever move 12 inches and disembar/embark? Link to comment Share on other sites More sharing options...
DarkGuard Posted August 19, 2009 Share Posted August 19, 2009 Not exactly, you can move at cruising speed down a road to 18" (you need to be on a road), and still disembark as its cruising speed. Also, I believe Stormtroopers can get out of a Valkyrie that moves flat out, but they have special rules for that. Link to comment Share on other sites More sharing options...
Redbaron997 Posted August 19, 2009 Author Share Posted August 19, 2009 Ah ok thank yall, its amazing how many times you can read over something you are looking for. Link to comment Share on other sites More sharing options...
Isiah Posted August 19, 2009 Share Posted August 19, 2009 Not exactly, you can move at cruising speed down a road to 18" (you need to be on a road), and still disembark as its cruising speed. Good point but not for fast skimmers as they ignore roads. 12" max for them or they're going flat out. Link to comment Share on other sites More sharing options...
DarkGuard Posted August 19, 2009 Share Posted August 19, 2009 Not exactly, you can move at cruising speed down a road to 18" (you need to be on a road), and still disembark as its cruising speed. Good point but not for fast skimmers as they ignore roads. 12" max for them or they're going flat out. Point to you too there Isiah, I'd forgotten about that. Link to comment Share on other sites More sharing options...
nighthawks Posted August 20, 2009 Share Posted August 20, 2009 Not exactly, you can move at cruising speed down a road to 18" (you need to be on a road), and still disembark as its cruising speed. Good point but not for fast skimmers as they ignore roads. 12" max for them or they're going flat out. missed that one. make sense, though... geesh Link to comment Share on other sites More sharing options...
