akaranseth Posted August 21, 2009 Share Posted August 21, 2009 I've posted a tutorial on painting metallic on my site: http://akaranseth.over-blog.com/pages/How_...ic-1650824.html It is pure theory for the moment. I should be adding examples eventually... Link to comment https://bolterandchainsword.com/topic/176443-tutorial-on-painting-metallic/ Share on other sites More sharing options...
Master Chaplain Astador Posted September 9, 2009 Share Posted September 9, 2009 Very good theory, very good tutorial even without photo's. Not to mention all of your works with TMM reflects the theory you've described. Glad to see you finally put this up! Link to comment https://bolterandchainsword.com/topic/176443-tutorial-on-painting-metallic/#findComment-2105506 Share on other sites More sharing options...
ulrikk Posted September 9, 2009 Share Posted September 9, 2009 Uh, apparently you already did a metallics tutorial. As a part of your Ultramarine Heavy Bolter Devastator. :P It looks very similar to the one you have planned, so I thought I'd post it for the viewing pleasure of any impatient Brothers out there. I'll be looking forward to the new metallics tutorial, that Ultramarine is a great mini! :D Link to comment https://bolterandchainsword.com/topic/176443-tutorial-on-painting-metallic/#findComment-2105990 Share on other sites More sharing options...
Master Chaplain Astador Posted September 10, 2009 Share Posted September 10, 2009 Uh, apparently you already did a metallics tutorial. As a part of your Ultramarine Heavy Bolter Devastator. :P It looks very similar to the one you have planned, so I thought I'd post it for the viewing pleasure of any impatient Brothers out there. I'll be looking forward to the new metallics tutorial, that Ultramarine is a great mini! :P While painted similarly, I believe Mathieu changed a few things in the process to achieve better results. Link to comment https://bolterandchainsword.com/topic/176443-tutorial-on-painting-metallic/#findComment-2106670 Share on other sites More sharing options...
akaranseth Posted September 11, 2009 Author Share Posted September 11, 2009 Uh, apparently you already did a metallics tutorial. As a part of your Ultramarine Heavy Bolter Devastator. :) It looks very similar to the one you have planned, so I thought I'd post it for the viewing pleasure of any impatient Brothers out there. I'll be looking forward to the new metallics tutorial, that Ultramarine is a great mini! :( It is indeed similar. But as Master Chaplain precised the artile on TMP is more advance and complete than the Space marine one. Link to comment https://bolterandchainsword.com/topic/176443-tutorial-on-painting-metallic/#findComment-2107776 Share on other sites More sharing options...
ulrikk Posted September 11, 2009 Share Posted September 11, 2009 I know you did. I just wanted to share the link to your nice metallics tutorial. It might be simpler than the one you are working on now, but it still gives an impressive result. But maybe I said it in a wrong way. :rolleyes: Link to comment https://bolterandchainsword.com/topic/176443-tutorial-on-painting-metallic/#findComment-2108092 Share on other sites More sharing options...
