Spacefrisian Posted August 22, 2009 Share Posted August 22, 2009 Before the new dex comes out i plan on running them in some tourneys over here. So what would you suggest i should add before they get their facelift. Leman Russ exterminator is one of those that will be in the list. Link to comment https://bolterandchainsword.com/topic/176558-spacewolves-before-facelift/ Share on other sites More sharing options...
Bran Scalphunter Posted August 22, 2009 Share Posted August 22, 2009 As many heavy weapon toting TDA Battle Leaders. I'd pass a brick of gold if those are in the new book. Link to comment https://bolterandchainsword.com/topic/176558-spacewolves-before-facelift/#findComment-2087227 Share on other sites More sharing options...
Spacefrisian Posted August 22, 2009 Author Share Posted August 22, 2009 Assaultcannon wielding tda HQ, can't miss out on that one off course. Link to comment https://bolterandchainsword.com/topic/176558-spacewolves-before-facelift/#findComment-2087243 Share on other sites More sharing options...
Wolf Guard Nostromo Posted August 22, 2009 Share Posted August 22, 2009 Wolf pelts - we sure aren't going to keep them - give them to every model in your army that can take them and don't worry too much about anyone charging you. Be ready to laugh when you have more attacks than them :P Runic charms are another good bet, so a big unit of TDA with an IC with an AC kitted out with runic charms and wolf pelts is a monster we are unlikely to see much more of... Link to comment https://bolterandchainsword.com/topic/176558-spacewolves-before-facelift/#findComment-2087313 Share on other sites More sharing options...
Spacefrisian Posted August 23, 2009 Author Share Posted August 23, 2009 Wolfpelts are standard issue with me. Link to comment https://bolterandchainsword.com/topic/176558-spacewolves-before-facelift/#findComment-2087767 Share on other sites More sharing options...
Demogerg Posted August 23, 2009 Share Posted August 23, 2009 I run my characters cheap, less than 100 points cheap, but I always take Wolf Pelts. (Frostblade, Stormshield, Wolf Pelt, Frag Nades on a Wolf Guard Battle leader) 11 blood claws with 3 powerfists is always nice, add a wolf guard with thunderhammer for lolz 12 S8 attacks on the charge, and 13 on the counter-charge. Wolf Scouts with meltabombs, flamer, 2x powerweapons, and a Wolf Guard Battle leader with thunderhammer/combimelta. they can threaten anything in the game, Meltabombs/combimelta pwns most vehicles, monstrous creatures can be dropped with the thunderhammer/powerweps, walkers can be stunned with the thunderhammer and dropped with meltabombs, lootas get dropped by the flamer, dev squads get eaten by power weps, the list goes on. Also Wolf Priests with healing potions and 4x fenrisian wolves in a unit of Wolf Guard with TDA, Runic Charms, and Stormshields.... 3+ invul save, 2+ regular save, ignore the first failed save, reroll the next failed save, when you DO finally fail a save you can remove a Fenrisian wolf instead of a marine, its worse than Nob Bikers. Link to comment https://bolterandchainsword.com/topic/176558-spacewolves-before-facelift/#findComment-2087846 Share on other sites More sharing options...
Rokafort Stonewolf Posted August 23, 2009 Share Posted August 23, 2009 Pack every bit of nasty you can into one list. OBEL scouts? Check. Vendread in a drop pod? Check. 2 dropping Terminator Squads of Doom? Check and Check. (WGBL with asscan, 2 asscans in squad...rest is up to you but I like combi-meltas on the other two guys, interchange power weapon, power fist, and a chainfist on one of the combi-melta guys). 15 blood claws in a Crusader? Check. RAWR! Link to comment https://bolterandchainsword.com/topic/176558-spacewolves-before-facelift/#findComment-2087855 Share on other sites More sharing options...
JCarter Posted August 24, 2009 Share Posted August 24, 2009 WGBL and retinue of 4 WG with 3 x Twinlinked lascannon, storm shields and runic charms. The other two WG in TDA with shields, charms and PWs as local security and, if points aren't a problem, throw in a Wolf Priest with healing potions and 4 x wolves. It's a great fire support in a high point game. Link to comment https://bolterandchainsword.com/topic/176558-spacewolves-before-facelift/#findComment-2088408 Share on other sites More sharing options...
EzE Posted August 24, 2009 Share Posted August 24, 2009 WGBL and retinue of 4 WG with 3 x Twinlinked lascannon, storm shields and runic charms. The other two WG in TDA with shields, charms and PWs as local security and, if points aren't a problem, throw in a Wolf Priest with healing potions and 4 x wolves. It's a great fire support in a high point game. That is likely technically legal, but it sounds morally wrong. <_< Link to comment https://bolterandchainsword.com/topic/176558-spacewolves-before-facelift/#findComment-2088548 Share on other sites More sharing options...
Spacefrisian Posted August 24, 2009 Author Share Posted August 24, 2009 I'am limited to 1500 points. For now i thought along the line of: WGBL with tda assaultcannon, pelt, Frostblade (with Greyhunters in Pod) SW Venerable Dreadnought + pod 3 wolfguard heavily equiped with stuf from the Armoury 4 or 5 Sw Scouts with Bombs, melta, plasmapistols 2 units of greyhunters 10 with pod, 9 with Rhino Bloodclaws with Rhino Exterminator Its not the best army but it includes alot of stuff that will most likely begone after we get a new Dex. Link to comment https://bolterandchainsword.com/topic/176558-spacewolves-before-facelift/#findComment-2088575 Share on other sites More sharing options...
Bran Scalphunter Posted August 24, 2009 Share Posted August 24, 2009 WGBL and retinue of 4 WG with 3 x Twinlinked lascannon, storm shields and runic charms. The other two WG in TDA with shields, charms and PWs as local security and, if points aren't a problem, throw in a Wolf Priest with healing potions and 4 x wolves. It's a great fire support in a high point game. That is likely technically legal, but it sounds morally wrong. ;) And that's why it's so good... Every once in a while you just gotta be bad. Link to comment https://bolterandchainsword.com/topic/176558-spacewolves-before-facelift/#findComment-2088880 Share on other sites More sharing options...
Valerian Posted August 24, 2009 Share Posted August 24, 2009 WGBL and retinue of 4 WG with 3 x Twinlinked lascannon, storm shields and runic charms. The other two WG in TDA with shields, charms and PWs as local security and, if points aren't a problem, throw in a Wolf Priest with healing potions and 4 x wolves. It's a great fire support in a high point game. That is likely technically legal, but it sounds morally wrong. :D And that's why it's so good... Every once in a while you just gotta be bad. How do Wolf Guard get twin-linked Lascannon? I suppose they could get Master Crafted, but TL? Link to comment https://bolterandchainsword.com/topic/176558-spacewolves-before-facelift/#findComment-2089039 Share on other sites More sharing options...
Bran Scalphunter Posted August 24, 2009 Share Posted August 24, 2009 Huh, I missed where he said TL. No, it should be Master-crafted at best. And the guys with LC can't have shields either. Only TDA Wolf Guard can take extra weaponry. Link to comment https://bolterandchainsword.com/topic/176558-spacewolves-before-facelift/#findComment-2089165 Share on other sites More sharing options...
