Spelling Question
ChainsawDR
Hi all,
Almost finished painting my Vindicator and I've named it "Russ's Fury" and painted along the front siege shield part - but my other half just questioned the spelling...
Before I go ahead and varnish it later I just wanted to check what you guys thought the correct spelling was. Is it "Russ's Fury", "Russes Fury" or "Russ' Fury"
Cheers brothers
ChainsawDR
https://bolterandchainsword.com/topic/176831-spelling-question/
Just got this online...
Some words sound awkward when an apostrophe 's' is added:
Jesus's disciples.
The accepted form here is to just use the 's' apostrophe:
Jesus' disciples.
N.B. This only applies to names of Biblical or historical significance e.g. Jesus, Moses, Zeus, Demosthenes, Ramses ... the rest of us whack in the apostrophe and add an 's.'
The princess's chair.
although Russ is biblical to me, this saves a re paint so will keep as "Russ's Fury"
Thanks guys
ChainsawDR
The spelling you have used "Russ's" is the correct one. You only omit the trailing s from the posessive case in situations where you do not pronounce the additional s.
So since this is basically pronounced "Russ's fury" and not "Russ fury" it is correct to leave the trailing s in place. You got it right.
Kenmichi I am afraid you are mistaken. Ommitting the s is the exception and not the rule. You only omit the s in the specific case where that trailing s would not be pronounced anyway. As rules of grammer go it's actually pretty straightforward, if you pronounce the s you write the s.
Read more at http://www.informatics.sussex.ac.uk/depart...000000000000000 if you really want.
As with a lot of things like this, it really depends who you ask. Certainly 'Russes' is totally wrong, as that is the plural of 'Russ'.
I do think Skalver is technically correct, however the other form would likely be considered acceptable usage in most cases.
Besides, it's the 41st Millennium and who knows how grammar would have changed :)
