Wargear and death
Generally, once the model dies its wargear has no more effect.
I would suppose you're right, if the standard-bearer dies then no one is rerolling their pinning tests any more. Our discussion revolved around the idea that a teleport homer or locator beacon is activated at the beginning of the battle so death of the bearer wouldn't have any impact.
If the standard bearer dies, no one sees the standard, if the Apothecary dies, no one can use the narthecium. But if the sarge with the beacon dies, the beacon is still there, flashing away. This is splitting hairs, though. For simplicity's sake I guess the wargear is useless if the unit dies. Otherwise would a DP's beacon still work if it's wrecked but not destroyed? Or would you roll to see if the beacon still works? Too complicated, I guess.
If the weilder dies the wargear stops functioning, assume it got shot, or requires an active component, or requires athorization to ensure it hasn been captured by the enemy.
As the homers are taken by the sergent, if the serg dies, it stops.
