Eviscerae Posted September 7, 2009 Share Posted September 7, 2009 I threw this together after some people asked me how I magnetized the bases of my (space hulk) terminators. This is used primarily to keep the lil' guys in my metal tool box. But you can use the same technique for just about any application. (featuring my cat... Justin) Hope it helps! Link to comment https://bolterandchainsword.com/topic/177865-magnetizing-space-hulk-bases/ Share on other sites More sharing options...
Brother Crassus Posted September 7, 2009 Share Posted September 7, 2009 2 quick suggestions for you: 1. a drill bit matching the diameter of your magnets will get a very precise and snug fit 2. in the case of the thin bases, pick up some thick plastic card.. blow a hole in it, glue to the bottom of the genestealer base, cut to fit... and voila. a thicker base. Link to comment https://bolterandchainsword.com/topic/177865-magnetizing-space-hulk-bases/#findComment-2103176 Share on other sites More sharing options...
Eviscerae Posted September 7, 2009 Author Share Posted September 7, 2009 2 quick suggestions for you: 1. a drill bit matching the diameter of your magnets will get a very precise and snug fit 2. in the case of the thin bases, pick up some thick plastic card.. blow a hole in it, glue to the bottom of the genestealer base, cut to fit... and voila. a thicker base. good suggestions. I'll have to try the plastic card out. Link to comment https://bolterandchainsword.com/topic/177865-magnetizing-space-hulk-bases/#findComment-2103335 Share on other sites More sharing options...
