Indie Characters w/JP or Bike joining Unit 50% in cover
Okay, so I was thinking tonight that if an IC decided to join a unit of say, a 10 man tactical squad that were over 50% in terrain cover; would he/she have to make a dangerous terrain check even if they simply became in coherency with the 2-3 models OUTSIDE the terrain? Obviously if the LOS is blocking over 50% of the squad where they aren't IN the terrain isn't the issue, its if they were.
No where in the rules does it talk about this. I've checked twice. :P
off the top of my head, You would not have to make the terain check when you join, as the character is independent during its move. However I am fairly certain you would have to make he check when the now joined unit leaves (next turn obviously)
Only if the IC actually landed in dangerous terrain. If part of a (jp)unit moves into dangerous terrain, only those model that actually touches the dangerous terrain should take the test (making it possible to loose the special weapon model)
