Azulz Posted September 10, 2009 Share Posted September 10, 2009 With the apothecary rule for DA does the wound get ignored before they roll to save or after? Link to comment Share on other sites More sharing options...
SeattleDV8 Posted September 10, 2009 Share Posted September 10, 2009 After, DA Codex pg. 25 "... to ignore a failed save (of any sort)." You have to make a save to fail it, or have it bypass your Armour (as in plasma weapons) Link to comment Share on other sites More sharing options...
Azulz Posted September 10, 2009 Author Share Posted September 10, 2009 Ahh thank you, yes I ge confused between the DA codex and rugular SM codex often. like for instance how smoke launchers work. But do WH apothecary's work the same way? Link to comment Share on other sites More sharing options...
Kronk Posted September 10, 2009 Share Posted September 10, 2009 After, DA Codex pg. 25 "... to ignore a failed save (of any sort)."You have to make a save to fail it, or have it bypass your Armour (as in plasma weapons) I'm not sure if I understand your reply, SeattleDV8. 1. It ignores a failed save, meaning you must make the save first. I agree here. 2. You must have made a save to have something to ignore, so wounds that bypass armor saves on models without a cover save or invulnerable save would not be ignored. No saving throw was ever taken. Link to comment Share on other sites More sharing options...
Frosty the Pyro Posted September 10, 2009 Share Posted September 10, 2009 After, DA Codex pg. 25 "... to ignore a failed save (of any sort)."You have to make a save to fail it, or have it bypass your Armour (as in plasma weapons) I'm not sure if I understand your reply, SeattleDV8. 1. It ignores a failed save, meaning you must make the save first. I agree here. 2. You must have made a save to have something to ignore, so wounds that bypass armor saves on models without a cover save or invulnerable save would not be ignored. No saving throw was ever taken. the save is automaticly failed, a wound that removes models (or removes a wound on multiwound) models is called unsaved, even if the model never rolled a save. Link to comment Share on other sites More sharing options...
Legatus Posted September 10, 2009 Share Posted September 10, 2009 the save is automaticly failed, a wound that removes models (or removes a wound on multiwound) models is called unsaved, even if the model never rolled a save. The rules for armour penetration do not describe it as automatically failing the save. They describe it so that the model does not get to make a save at all. Failing a save and not getting a save is not exactly the same, even though both will result in an unsaved wound. The Dark Angels Narthecium does not work on unsaved wounds though, but they require a failed save. Link to comment Share on other sites More sharing options...
Ming Posted September 10, 2009 Share Posted September 10, 2009 Yep, just like FNP with a current SM Apoth, the older rules would apply to ignoring a save-able save. "I'm shot doc" ...."Don't worry about that, gotcha covered"..."but...It was a plasma round"...."OK, sorry bud, time to remove the gene seed..."...click click pull... Link to comment Share on other sites More sharing options...
