Ragnar the great Posted September 23, 2009 Share Posted September 23, 2009 guys being painting converting bits on my models and busy with my pred. now it only has on the sides 2 las cannons and on the turret and auto cannon, but also has my dude with a storm bolter. so with me attacting magnets all over the place i stuck 1 on the storm bolter just for transport reasons, but then i started to wounder about weapons destoryed... would that storm bolter count as a weapon destoryed? Link to comment https://bolterandchainsword.com/topic/179381-qa-brothers/ Share on other sites More sharing options...
thade Posted September 23, 2009 Share Posted September 23, 2009 Not sure what you're asking here...I'll give it a guess? If your opponent scores a Weapon Destroyed result on your tank, they can select any weapon on it that they want destroyed. Once all the weapons on it are gone, a weap destroyed result = immobile, then beyond that, weapon destroyed= wrecked. So assuming your opponent has a weird (but not uncommon) streak of scoring repeated weapon destroyed results on your tank, they will choose the best weapon (roughly) each time they can. Eventually you could lose that Storm Bolter. Is that what you are asking? Using magnets so you can pull of weapons for either options or to represent destroyed is good (I've started doing it, I'm a fan). If you are asking whether you should magnetize the storm bolter, sure you can. I do not, actually...I magnetize everything else. If the storm bolter is destroyed, I throw a Weapon Destroyed counter on the tank. Link to comment https://bolterandchainsword.com/topic/179381-qa-brothers/#findComment-2122692 Share on other sites More sharing options...
