Furious charge and power fists
spectre312
  waaanial00 said:
Dont forget that they have a +1 AFTER the doubling of the strength. So for example a Marine with power fist will strike at I1 S9!!!! Up to a max of S10 though.
Which is quite pointless as already S8 will wound T6 models on 2+ and instant-kill T4 models. The only benefit S9 will give you is against T7 models, and I can't readily come up with anyone.
Now, against vehicles S9 have merit, but only for Power Armoured Sergeants as you should have a Chainfist in your Terminator Squad giving you significantly better armour penetration.
  marine said:
doesn't the rule book say powerfists are always initiative 1 regardless of grenades or furious charge
Indeed BRB p42:
"Power fists, however, [...] are always delivered at Initiative 1 (ignore Initiative bonuses from special rules, wargear etc.)."
Upgraded carnifex can be T7. Wraithlords are T8. Also S9 can pen AV 14, S8 cannot. It matters.
  Frosty the Pyro said:
  DevL said:
  waaanial00 said:
Dont forget that they have a +1 AFTER the doubling of the strength...
Which is quite pointless...
It also bear mention that there are a number of S3 models in the game (IG, for one) that can be equipped with a fist. Not everything is MEQ
