Chapter Master Vaako Posted September 28, 2009 Share Posted September 28, 2009 Hi everyone and thanks for looking! This is my first tutorial ever so trying to make it a good one. This tutorial will show you how you can make a simple chainfist from the AoBR contents only. You will need: A terminator (duh), A terminator power sword arm, An ork chainsaw (no hilt etc. just the chainsaw body) Milliput/greenstuff etc. Glue (plastic or super) Sculpting tool knife file 1. Cut the hilt and pommel from the sword arm and file both sides smooth. 2. Cut the power cable leading from under the shoulder pad halfway, to the top of the elbow pad. 3. Glue chainsaw to the underside of the arm getting as close to the pipe as possible. 4. Use milliput/greenstuff to blend the power cable and chainsaw together. 5. (optional) This step is optional but i added a button on top of the hand to represent a shaft that is connected to the chainsaw which the termie uses it with. I hope you have enjoyed this article and good luck cutting through those tanks! (Sorry about the lack of pics but camera is broke so no pictures for a while hope you can still work it out though) Link to comment https://bolterandchainsword.com/topic/179852-easy-chainfists/ Share on other sites More sharing options...
TheBobulator Posted October 2, 2009 Share Posted October 2, 2009 Hmmm...there is another tut for this already, but i'd still like to see it... Link to comment https://bolterandchainsword.com/topic/179852-easy-chainfists/#findComment-2133909 Share on other sites More sharing options...
