Warprat Posted September 29, 2009 Share Posted September 29, 2009 Questions: 1) Can the LOTD ride on the Rhino and fire hyv weapons? At full speed? 2) Can the LOTD unload and assault if the Rhino has moved? Thanks! Warprat ;) Link to comment Share on other sites More sharing options...
SeattleDV8 Posted September 29, 2009 Share Posted September 29, 2009 1) Slow & Purposeful allows them to move 6" embarked and still fire Hvy weapons. 2) No, as per any other normal unit. Link to comment Share on other sites More sharing options...
Frosty the Pyro Posted September 29, 2009 Share Posted September 29, 2009 1) Slow & Purposeful allows them to move 6" embarked and still fire Hvy weapons. 2) No, as per any other normal unit. I confirm this. simply pretend all their weapons are assult weapons and treat them as regulare troops otherwise. Link to comment Share on other sites More sharing options...
OwlandMoonGuy Posted September 29, 2009 Share Posted September 29, 2009 The Relentless rule, BRB pg 76 specifically mentions “movement” without specifying movement made under a model’s own power or via a transport. So per the first question, “Relentless models can shoot with rapid fire and heavy weapons counting as stationary, even if they moved in the previous Movement phase, and are also allowed to assault in the same turn they fire them.” The limitations from disembarking are found on pg. 67, “If the vehicle has already moved (…), the passengers may disembark, but not move any further in the Movement phase… After disembarking, these models may shoot (counting as moving), but may not assault. In the case of Relentless models, they may disembark from a transport that moved and then fire counting as stationary. Yet, they still could not assault. This is a limitation imposed by disembarking from a transport not by the limitation imposed by firing weapons. -OMG Link to comment Share on other sites More sharing options...
Warprat Posted October 1, 2009 Author Share Posted October 1, 2009 The Relentless rule, BRB pg 76 specifically mentions “movement” without specifying movement made under a model’s own power or via a transport. So per the first question, “Relentless models can shoot with rapid fire and heavy weapons counting as stationary, even if they moved in the previous Movement phase, and are also allowed to assault in the same turn they fire them.” The limitations from disembarking are found on pg. 67, “If the vehicle has already moved (…), the passengers may disembark, but not move any further in the Movement phase… After disembarking, these models may shoot (counting as moving), but may not assault. In the case of Relentless models, they may disembark from a transport that moved and then fire counting as stationary. Yet, they still could not assault. This is a limitation imposed by disembarking from a transport not by the limitation imposed by firing weapons. -OMG Thanks for the replies everyone! OMG, I assume that you also agree that the Rhino can only move up to Combat Speed 6" (for regular Rhinos) and have the LOTD still be able to fire? Warprat ;) Link to comment Share on other sites More sharing options...
Frosty the Pyro Posted October 1, 2009 Share Posted October 1, 2009 The Relentless rule, BRB pg 76 specifically mentions “movement” without specifying movement made under a model’s own power or via a transport. So per the first question, “Relentless models can shoot with rapid fire and heavy weapons counting as stationary, even if they moved in the previous Movement phase, and are also allowed to assault in the same turn they fire them.” The limitations from disembarking are found on pg. 67, “If the vehicle has already moved (…), the passengers may disembark, but not move any further in the Movement phase… After disembarking, these models may shoot (counting as moving), but may not assault. In the case of Relentless models, they may disembark from a transport that moved and then fire counting as stationary. Yet, they still could not assault. This is a limitation imposed by disembarking from a transport not by the limitation imposed by firing weapons. -OMG Thanks for the replies everyone! OMG, I assume that you also agree that the Rhino can only move up to Combat Speed 6" (for regular Rhinos) and have the LOTD still be able to fire? Warprat :P Of course, essentialy all relentless or slow and purposefull does is make all their weapons assult instead of what they normaly are Link to comment Share on other sites More sharing options...
