Advice please
Thunder_god
I'm planning on basing my Wolves on 2 of the up coming battle forces. That's 40 Marines, probably all to be kitted as Gray Hunters, and 10 scouts. I have rhinos to supplant the 2 drop pods.
Apart from the obligatory wolfy HQ's needed, what else would y'all recommend. I haven't seen wolves played heavily since 3rd when I was in college, so I'm out of the loop here.
Thanks everyone.
https://bolterandchainsword.com/topic/180104-advice-please/
I suggest you buy 2 Rhinos(of course buy the RB kit and make it interchangable). This will give you 4 GH squads 2DP and 2Rhinos. If you build your HQs and WG in PA from the Space Wolf kits, you can run a 1500 point force by adding some AT pretty easily. FYI your going to need to come up with some MG bits, for your GH kits.
As for the AT force, it's a bit of a toss up and personal prefrence on what to buy. You can go Swift Claws with AB MM add a WG on Bike for a pretty nasty AT unit that can provide support to the DP pretty quickly. LF or Vindi is always a good bet. If you going to run Vindi as AT then you need 2.
WG Vrox.
https://bolterandchainsword.com/topic/180104-advice-please/#findComment-2132437
