Rune Priest: Master of Chooser
dublindawg
I was reading through the codex over the weekend, if you give your RP the master of the chooser it allows you to place a marker anywhere on the table. The marker has to be smaller than the RP model you are using and while a die is simple enough, something more substancial is needed.
Has anyone figured out what they plan on using for the marker besides a dice? While I am tempted to place the cyber raven that Njal has on it's own base I'm just not sure.
Any thoughts?
https://bolterandchainsword.com/topic/180617-rune-priest-master-of-chooser/
choosers of the slain can be anything you want. From the fabled psychic foxes of old, to ravens, eagles etc. Yet for some reason, after watching the movie Wolfhound, I wanna do a chooser of the slain with a bat! LOL it was the main character's pet companion.
I use Warmaster bitz for mine: the Carrion and Great Eagles are both somewhat the right size and easily available (as a box of 3, so not a bankbreaker).
add http to both links
://www.games-workshop.com/gws/catalog/productDetail.jsp?catId=cat1300017&prodId=prod1130116
://www.games-workshop.com/gws/catalog/productDetail.jsp?catId=cat1300013&prodId=prod1130088
I cut the Cyber Raven off of the old Njal Model and mounted in onto a small clear base. It should work great. I then added a bolt pistol to the old Njal model and used him extensively in 4th edition. (Not so much in 5th). That way I was able to add the Cyber Raven as wargear before.
