Sculpting a wolf cloak
stinkenheim
Ok, heres the start of my tutorial on scultping a wolf cloak, i'm only part way through, the scond part should be online tomorrow sometime, and will be followe up by a tut on how i paint my fur.
Firstly get your model, a fairly obvious step but i had to start somewhere... here my wolf lord, hes sad and cold cos he has no cloak ;)
http://i400.photobucket.com/albums/pp86/stinkenheim/DSC00710.jpg
The mix up some greenstuff and tease it out into thin strips, these will form the legs of your pelt.
A good tip for when you do this, is once each limb is placed roughly where you want, put a thin layer of superglue over the greenstuff. When this dries it should help to keep the greenstuff in place while it cures.
If the cloak is going to be away from the model, and therefore will have nothing to rest on while it dries, use a lump of blu-tak to help it hold its shape.
http://i400.photobucket.com/albums/pp86/stinkenheim/DSC00711.jpg
http://i400.photobucket.com/albums/pp86/stinkenheim/DSC00712.jpg
http://i400.photobucket.com/albums/pp86/stinkenheim/DSC00713.jpg
Once you have the basic skeleton of the cloak (dont worry about how messy or poo this looks) you need to start adding the claws.
i've found out the hard way that its a bad idea to sculpt the fur before the claws...
http://i400.photobucket.com/albums/pp86/stinkenheim/DSC00714.jpg
I make the claws by rolling out a small point of greenstuff, make sure you have a bit extra on the opposite end to the point, this is waht you will attatch the claw to the pelt with.
http://i400.photobucket.com/albums/pp86/stinkenheim/DSC00716.jpg
i then carefully pick it up with my sculpting tool before positioning it where i want it to go. I find its best to have it overhanging the cloak, although you dont have to, it just looks better in my opinion. Then use flatten the excess greenstuff onto the paw.
http://i400.photobucket.com/albums/pp86/stinkenheim/DSC00717.jpg
http://i400.photobucket.com/albums/pp86/stinkenheim/DSC00718.jpg
This should give you a look a bit like this
http://i400.photobucket.com/albums/pp86/stinkenheim/DSC00719.jpg
Thats the end for part one, i will start scultping the fur once this has dried and keep you posted guys.
https://bolterandchainsword.com/topic/180642-sculpting-a-wolf-cloak/
i have done a tut on wolf tooth necklaces and wolf tail talismans its here http://www.bolterandchainsword.com/index.p...6089&st=200
the shield is from the lmtd edition white dwarf on shield bearers (the one where gotrek and bugman held him up) i've filed the runes off of it and i'm gonna put a layer of greenstuff over the top to smooth it out. When its done im gonna paint his emblem and 'stuff' on it to look like its been etched in metal.
the hammer is from a dwarf engineer with great weapon in fact its this guy here http://www.games-workshop.com/gws/catalog/...odId=prod780870
the hand that holds it is from the current techmarine.
the wolf head was taken from logan grimnar, i had half of one i got off of ebay for about £1 and decided to use it.
as for shields, i have a pair of these from the CMON shop, http://www.coolminiornot.com/store/product.php?xProd=2490 they are a tiny bit bigger than the one on the mini above but a good fit and they have a decent pattern on them... mine differ slightly in terms of the pattern they have on the front but they are a nice fit for termies.
alternatively there are these, similar size to the one above but plain http://www.coolminiornot.com/store/product.php?xProd=2489
ok once you have the skeleton of the cloak made then start laying a strip of greenstuff on top of one of the limbs.
its easiest to start on a limb as the fur should be scultped in lines pointing down and it makes blending later stages easier.
heres a shot of the one leg with fur added
http://i400.photobucket.com/albums/pp86/stinkenheim/DSC00767.jpg
when you reach the top of the leg make sure to flatten the greenstuff out as much as possible like this pic, this is to make later stages easier.
http://i400.photobucket.com/albums/pp86/stinkenheim/DSC00764.jpg
ok you should soon have all the legs finished
http://i400.photobucket.com/albums/pp86/stinkenheim/DSC00769.jpg
the nex tpart is the tail (and my pic didnt come out properly, dammit). but basially wrap a thin layer of greenstuff around the tail, making it thicker at the base of the tail. leave it to cure for about 20 mins. start working at the tip of the top side in the same manner as the fur on the legs. once the top is done do the same on the bottom, then neaten up the edges.
afterwards, add a patch going across the width of the cloak, filling about half the remaining gap. then just start scoring lines in to make the texture. as long as the new layer is added about where the layer from the legs thinned it should be pretty easy to get the two layers to blend.
http://i400.photobucket.com/albums/pp86/stinkenheim/DSC00770.jpg
then again, add another layer (this should be the final one) and sculpt the fur into this. this one is a bit different however as it will likely meet up with the wolfs head, as such the fur needs to be sculpted in a different way. excuse the poor pics but this is asimple way for me to describe it.
as you can see the fur (the little black lines) are pointing towards the end of the limbs...
http://i400.photobucket.com/albums/pp86/stinkenheim/fur.jpg
now we need the fur to turn to point down the top legs... to do this the fur should be scultped in this sort of pattern.
at the middle of the neck, the fur is pointing down, but as you move further from the centre the fur should start to curve slightly.
http://i400.photobucket.com/albums/pp86/stinkenheim/fur2.jpg
it should look something like this when finished
http://i400.photobucket.com/albums/pp86/stinkenheim/DSC00779.jpg
http://i400.photobucket.com/albums/pp86/stinkenheim/DSC00780.jpg
and thats pretty much that for this part... the only bit left is to sculpt the skin on the underside, but i need the fur to have dried fully before i do that...
once the fur cloak is sculpted you need to start adding the skin underneath in any visible areas... this is so simple to do, and far easier than sculpting the rest of it in the first place.
layer a thin piece of greenstuff within the outlines of the fur like below
http://i400.photobucket.com/albums/pp86/stinkenheim/DSC00786.jpg
then using you sculpting tool roughly spread it about, pulling it closer to the edge
http://i400.photobucket.com/albums/pp86/stinkenheim/DSC00787.jpg
then using the blade part of your tool start to make the edge irregular and add small 'holes' and dots in random places. also make sure the greenstuff layer isn't flat, as when you come to paint it the rough texture will look better.
http://i400.photobucket.com/albums/pp86/stinkenheim/DSC00789.jpg
all you need to do is finish the rest of the visible underside in the same manner to complete your fur cloak...
in a few days i'm gonna get round to painting it so i'll post up the tutorial of that in this thread too.
a terran wolfs is yes but these are from a speshul kind of fenrisian wolf with a funny looking tale,,,
i based this on grimnars which is conical, besides it looks better and provides more support for the tail when it comes to posing it and painting it. the last thing you want is for the tail to snap off when your handling it.
+edit+ thought i'd add in the tutorials for accessories that i poseted up here a while ago...
first up, wolf tail talismans...
take a small cone of greenstuff, smaller than you want the finished talisman to be...
http://i400.photobucket.com/albums/pp86/stinkenheim/DSC00509.jpg
then using a sculpting tool or knife blade (make sure your tools are wet to stop the greenstuff sticking) score lines from top to bottom, this will lengthen the cone. when you get to the bottom of the talisman pull a couple of the strands outward slightly, and pull a few out from the sides to give a nice look to it.
http://i400.photobucket.com/albums/pp86/stinkenheim/DSC00511.jpg
then square off the top slightly and also take a small piece out of the top corners so the top looks something like this /-\
http://i400.photobucket.com/albums/pp86/stinkenheim/DSC00512.jpg
then take a small ball of greenstuff and place it on the top, you might need to shape it slightly when its there but it should look like the tail comes out and then expands slightly (gives the impression that the metal clasp is pinching the hair together)
http://i400.photobucket.com/albums/pp86/stinkenheim/DSC00513.jpg
then lastly score a small line just above the bottom of the ball of greenstuff... if you want you can instead add a small sauage of greenstuff but this is quicker and easier and looks fine. it just gives you th slight rim that you find on the plastic taismans.
http://i400.photobucket.com/albums/pp86/stinkenheim/DSC00515.jpg
and there you go, a finished wolf tail talisman...
next up, runic charms and wolf tooth necklaces...
for the charm take a blob of greenstuff (yes 'blob' is a technical term... i went on the course you see)
http://i400.photobucket.com/albums/pp86/stinkenheim/DSC00516.jpg
flatten it and square off some of the edges, try and make it look irregular if you can
http://i400.photobucket.com/albums/pp86/stinkenheim/DSC00517.jpg
then using the tip of your scultping tool (or if its a really small charm your scalpel... jst be carefull if you put it in your move to moisten the blade cos tongues take ages to stp bleeding) and score in your chosen rune and a small dot at the top of the charm
http://i400.photobucket.com/albums/pp86/stinkenheim/DSC00518.jpg
for teeth i find if you add a small, thin cone of greenstuff and shape it with a slight bend in it you should get a nice tooth like shape. if you can, a small nick at the top gets the shape of roots. but make sure you add a dot like you did with the charm.
http://i400.photobucket.com/albums/pp86/stinkenheim/DSC00519.jpg
well now you need something to attatch them to, so take a thin sausage of greenstuff and place it just above
http://i400.photobucket.com/albums/pp86/stinkenheim/DSC00520.jpg
and lastly using some more thin strips of greenstuff make the mtal rings, or leather straps that attatch the teeth and charms to the necklace... place one end in the small dots you made and then cut the sausage just above the necklace strap... and voila, a quick necklace is done :)
http://i400.photobucket.com/albums/pp86/stinkenheim/DSC00521.jpg
ok, the last part of this (at least at the moment) is the painting of fur. I've been asked by a few people but couldn't do it until i actually had some fur that needed to be painted... well here it is.
Firstly, i know many of you undercoat, but for the purposes of this tut and because of the dark colours involved i painted it straight onto the grenstuff so that you could see.
Secondly, you will need some sort of picture to base your painting on. any image will do, i put 'Wolves' into google and picked out a few nice ones.
My wolves tend to be brown in colour rather than grey, but thats because my space wolves are pretty cold so it brings a bit of warmth to the model. If you decde that you really want grey/black wolves then go for it, the way i pait it should easily be applicable to whatever your scheme is.
this is the picture i chose
http://i400.photobucket.com/albums/pp86/stinkenheim/wolf.jpg
I used the following colours;
Chaos Black
Scorched Brown
Bestial Brown
Snkebite Leather
Desert Yellow
Bleached Bone
Skull White
and finally Gryphonne Sepia...
it sounds like a big list, but you could easily get rid of bestial brown and probably snakebite leather if you need to.
whatever colours you use, make sure they are watered down, not too muh, but you need to be able to blend the two together (really not as hard as it sounds).
the basic technique is pretty simple, paint one colour, leave a slight gap and then paint the next xolour. you then drag the loghter colour back into the dark one. a bit like this
http://i400.photobucket.com/albums/pp86/stinkenheim/DSC00816.jpg
http://i400.photobucket.com/albums/pp86/stinkenheim/DSC00817.jpg
First up i painted the head to be similar to the picture i chose. I started with painting black down the middle of the head, scorched brown was then painted around the black areas, blending the two colours together. I then progressed down the colour chart until i was happy with how the head turned out.
http://i400.photobucket.com/albums/pp86/stinkenheim/DSC00807.jpg
i then started painting the leg, i made sure t use a similar pattern to the wolf, dark near the shoulder, brighter to the bottom.
http://i400.photobucket.com/albums/pp86/stinkenheim/DSC00808.jpg
I started on the back, as this is a pretty large area its easy to show you the technique at work. sorry about the blurry shot (i had to work quickly and didn't notice).
Paint black down the middle of the back
http://i400.photobucket.com/albums/pp86/stinkenheim/DSC00809.jpg
then paint scorched brown either side of the black and blend the two in.
http://i400.photobucket.com/albums/pp86/stinkenheim/DSC00810.jpg
bestial brown was then added again moving further to the edges of the cloak and being blended into the previous layer
http://i400.photobucket.com/albums/pp86/stinkenheim/DSC00811.jpg
snakebite leather was added in the same manner as the previous steps
http://i400.photobucket.com/albums/pp86/stinkenheim/DSC00812.jpg
lastly a thin layer of desertyellow was applied, just along the edges
http://i400.photobucket.com/albums/pp86/stinkenheim/DSC00813.jpg
i then painted the tail in much the same way, but keeping the top side darker and the underside getting lighter
http://i400.photobucket.com/albums/pp86/stinkenheim/DSC00814.jpg
when you finish the remaining legs it should look like this
http://i400.photobucket.com/albums/pp86/stinkenheim/DSC00815.jpg
you then need to drybrush the fur. this is really easy to do. make sure you drybrush the colours onto the previous layer. E.g scorched brown is drybrushed over the areas you painted chaos black. The scorched brown areas are drybrushed bestial brown and so on. when you get to he bleached bone areas simply lightly drybrush them with skull white.
I very often give the fur a very, very light drybrush of desert yeallow then bleached bone to stop the darker areas from looking too flat.
when you have drybrushed give the entire area a coat of gryphonne sepia, this adds depth to the fur as it sits in the recesses. it should look like this
http://i400.photobucket.com/albums/pp86/stinkenheim/DSC00828.jpg
http://i400.photobucket.com/albums/pp86/stinkenheim/DSC00831.jpg
if the lighter areas need it simply apply another drybrush of bleached bone and white.
For the underside, this is so simple. Paint the entire area bleached bone
http://i400.photobucket.com/albums/pp86/stinkenheim/DSC00818.jpg
add a wash of gryphonne sepia. its at this stage that you see why its best to give the skin a slight texture, as the wash sits in the recesses
http://i400.photobucket.com/albums/pp86/stinkenheim/DSC00820.jpg
then highlight with bleached bone, and then a final highlight of bleached bone/skull white
http://i400.photobucket.com/albums/pp86/stinkenheim/DSC00821.jpg
i paint my eyes yellow, using Iyaden darksun as the base colour, then a pupil of black as a line in the centre of the eye.
the claws/teeth are painted by gving them a basecoat of snakebite leather and then highlighting up towards the tip with bubonic brown, bleached bone and a final highlight of skull white.
[Vader] Impressive.....Most Impressive. [/Vader]
As an additional reference resource I offer this: http://www.tamaskan-dog.com/The%20Standard...ic_standard.htm There are plenty of images available on the web by doing an image search for "Wolf" or derivitives there of, or by using Siberian Husky or Alaskan Malamute as alternative searches for color variations.
I am going to add my own 'omg' comment to this. Awesome tutorial
I would also like to know the bit of how you actually 'sculpted' the fur effect as none of mine ever came out like that - it really looks good
And big thanks for the painting steps - really helps a lot for a very effective finish
Mods. Can we have this 'stickied'??
DGC
with regards to the 'way' i scultped the fur... i did actually do a video on my camera showing sculpting fur and the underside of the pelt but whenever I try and upload it to either youtube or myspace my internet cuts out, anyone have any ideas why??
but sure, i'll take a few pics of how i do it. probably have them on here by wednesday.
@ the god emperor, what exactly was it you were unsure of?
oh, by the way guys, the sculpting part was added to the librarium here http://www.bolterandchainsword.com/index.p...showarticle=705
and they explained some bits better than me :D
  • 9 months later...
