Grey Mage Posted October 7, 2009 Share Posted October 7, 2009 I'm leaning towards a Long Fang Pack with 2x Lascannons, 3x Heavy Bolters riding around in a TLHB Razorback. Can someone clarify why adding a WG as an ablative wound is better than the cc/bp 6th Long Fang that you can get in your squad? Just to avoid losing Fire Control? I mean...15 pts is less than 18 pts after all. Im pretty sure you cant have a HWless LF in the pack, save for the leader. Link to comment https://bolterandchainsword.com/topic/180674-long-fangs-in-the-white-dwarf/page/2/#findComment-2141158 Share on other sites More sharing options...
Emperor's Scourge Posted October 7, 2009 Share Posted October 7, 2009 Yep...thats who I was referring too. My question was; why is a WG better than the LF squad leader? If you're going for just a regular bp/cc set up then the LF SL is 3 pts less than a base WG. Link to comment https://bolterandchainsword.com/topic/180674-long-fangs-in-the-white-dwarf/page/2/#findComment-2141161 Share on other sites More sharing options...
Grey Mage Posted October 7, 2009 Share Posted October 7, 2009 Yep...thats who I was referring too. My question was; why is a WG better than the LF squad leader? If you're going for just a regular bp/cc set up then the LF SL is 3 pts less than a base WG. Because if you lose the Pack Leader you cant keep splitfiring? Link to comment https://bolterandchainsword.com/topic/180674-long-fangs-in-the-white-dwarf/page/2/#findComment-2141177 Share on other sites More sharing options...
Vilhelm Posted October 7, 2009 Share Posted October 7, 2009 I'm with jaarl... What makes Long Fangs special is their cheapness. There are only 3 reasons I can see of to pay for a Wolf Guard to lead the pack- More firepower for the squad (cyclone Termie), an ablative wound, or Leadership 9. Cyclones are way too expensive, and offset the cheapness. For me this means they are a no go! Ablative wound? I plan to just take some heavy bolters. That way they are a *functional* ablative wound. They can split fire, so it's not like they dilute the firepower. If you need more of the big guns, take a second squad or give them a razorback. Finally, there's Leadership 9. This is the only compelling argument for me. Leadership 9 is nice- But not quite nice enough for it to be worth it. I prefer to take a nice low cost Long Fang squad, primarily ML's and HB's, and stick them behind some cover within Heavy Bolter Range of at least 1 objective, and forget about them. The special characters and vehicles we need these days are enough of a points sink as it is. Who needs to go nuts on long fangs? Link to comment https://bolterandchainsword.com/topic/180674-long-fangs-in-the-white-dwarf/page/2/#findComment-2141209 Share on other sites More sharing options...
Brother-Captain Sicarius Posted October 7, 2009 Share Posted October 7, 2009 Finally, there's Leadership 9. This is the only compelling argument for me. Leadership 9 is nice- But not quite nice enough for it to be worth it. correct me if im wrong, but ain't the LF's LD9 from the start? Link to comment https://bolterandchainsword.com/topic/180674-long-fangs-in-the-white-dwarf/page/2/#findComment-2141341 Share on other sites More sharing options...
Brother Amarel Posted October 7, 2009 Share Posted October 7, 2009 Finally, there's Leadership 9. This is the only compelling argument for me. Leadership 9 is nice- But not quite nice enough for it to be worth it. correct me if im wrong, but ain't the LF's LD9 from the start? Yup, LD9 for LF's. Link to comment https://bolterandchainsword.com/topic/180674-long-fangs-in-the-white-dwarf/page/2/#findComment-2141343 Share on other sites More sharing options...
