Brother_Beork Posted October 6, 2009 Share Posted October 6, 2009 Sometimes people just want parts instead of whole marines. This is one such occasion. I was asked to make a fist and legs like those of the BlackHands captain, but without bionics. Also the fist should sport a stormbolter which should be less blocky and somewhat concealed when compared to the first prototype of the BlackHands captain. So it was that I started on the legs and fist by cutting them apart. http://img.photobucket.com/albums/v331/brother_beork/Commissions/Bits%20and%20Pieces/100_7744.jpg Then I added plates and rims (no in between photo’s, sorry) http://img.photobucket.com/albums/v331/brother_beork/Commissions/Bits%20and%20Pieces/100_7831.jpg The fist got a shaved clean and pinned and some plasticard was added to make the position as it should http://img.photobucket.com/albums/v331/brother_beork/Commissions/Bits%20and%20Pieces/100_7739.jpg And then got glued in the proper position and GS’ed to replace shaved off parts. http://img.photobucket.com/albums/v331/brother_beork/Commissions/Bits%20and%20Pieces/100_7834.jpg To do: - Add stormbolter and curved armour plate (I’ve got a shield shaped plate ready for this) - GS joints of the fist - Re attach the cables the fist had - Put the legs together - Add rivets to rim - GS joints NeDlols, Do you have a specific chapter symbol? I might be able to do something with the sole of the feet (if it’s not to complicated that is) Beork Link to comment https://bolterandchainsword.com/topic/180695-legs-and-fist/ Share on other sites More sharing options...
NeDlols Posted October 6, 2009 Share Posted October 6, 2009 He's gonna be an Ultra-smurf (nothing like the good old 40k posterboys). So if you could do something with the sole to go with that I'd be over the moon :) Link to comment https://bolterandchainsword.com/topic/180695-legs-and-fist/#findComment-2139506 Share on other sites More sharing options...
Brother_Beork Posted October 20, 2009 Author Share Posted October 20, 2009 Legs are riveted: http://img.photobucket.com/albums/v331/brother_beork/Commissions/Bits%20and%20Pieces/100_8031.jpg This time I didn't glue the rod on before filing, but in. I got me a set of 0,3-1.5 mm drills in steps of 0,05mm :P The rods for the greaves are 0,65 mm so I used the 0,60mm drill for a snug fit. It works very well although it is a bit more time consuming and less forgiving (no more shoving the rivet around for the perfect place. But in the long run it whould save time (no more rivets falling off etc.) Legs will be attached somewhere soon and I'm still wokring on the fist Beork Link to comment https://bolterandchainsword.com/topic/180695-legs-and-fist/#findComment-2156742 Share on other sites More sharing options...
Brother_Beork Posted November 27, 2009 Author Share Posted November 27, 2009 Progress, almost done even. http://img.photobucket.com/albums/v331/brother_beork/Commissions/Bits%20and%20Pieces/100_8190.jpg http://img.photobucket.com/albums/v331/brother_beork/Commissions/Bits%20and%20Pieces/100_8191.jpg Now to add some cables, decoration and ribbing. Beork Link to comment https://bolterandchainsword.com/topic/180695-legs-and-fist/#findComment-2197652 Share on other sites More sharing options...
NeDlols Posted November 27, 2009 Share Posted November 27, 2009 Thats looks fantastic, you've intergrated the stormbolter perfectly. I can't wait to see it finished :) Link to comment https://bolterandchainsword.com/topic/180695-legs-and-fist/#findComment-2197765 Share on other sites More sharing options...
Brother_Beork Posted November 27, 2009 Author Share Posted November 27, 2009 glad you like the progress, took longer than expected due to sickness and work, should be done quickly now, just the decoration that'll be troublesome as my etchings all fail, next weekend I get a new batch of high grade acid, so maybe it'll work then. Else I'll have to skip them, sadly. Anyway, any last term changes, ideas? tassles are in the works. cheers, Beork Link to comment https://bolterandchainsword.com/topic/180695-legs-and-fist/#findComment-2197777 Share on other sites More sharing options...
NeDlols Posted November 27, 2009 Share Posted November 27, 2009 Thats a shame to hear about the etching don't worry about it tho, a couple of purity seals to one of the legs would be more than enough as I plan to freehand most of the details in. The only change I'd like to the model is if you could rotate the bolter barrels so the holes are horizontal instead of vertical. :) Link to comment https://bolterandchainsword.com/topic/180695-legs-and-fist/#findComment-2197790 Share on other sites More sharing options...
Brother_Beork Posted November 27, 2009 Author Share Posted November 27, 2009 Cool, Barrels will be turned. I liked them better this way, but you'r ethe boss. cheers, Beork Link to comment https://bolterandchainsword.com/topic/180695-legs-and-fist/#findComment-2197797 Share on other sites More sharing options...
Guyver3x Posted November 27, 2009 Share Posted November 27, 2009 Your stuff always looks awesome. I think I know where NeD is coming from with the bolter barrels. If they were that way , the exhaust gasses would go into the top of the fingers, rather than away from the fist. really not a criticsim, more an observation. Always look forward to seeing more Link to comment https://bolterandchainsword.com/topic/180695-legs-and-fist/#findComment-2197842 Share on other sites More sharing options...
Brother_Beork Posted November 27, 2009 Author Share Posted November 27, 2009 I would assume the holes on the other side to be closed (no idea if that affects the working of a gun). I thought it would look mighty steampunk if the fist would have sideward gasflow every shot. Beork Link to comment https://bolterandchainsword.com/topic/180695-legs-and-fist/#findComment-2197849 Share on other sites More sharing options...
Brother_Beork Posted December 2, 2009 Author Share Posted December 2, 2009 I could do this to ultrafy the legs/fist: http://img.photobucket.com/albums/v331/brother_beork/Commissions/Bits%20and%20Pieces/100_8221.jpg http://img.photobucket.com/albums/v331/brother_beork/Commissions/Bits%20and%20Pieces/100_8222.jpg Comes from a shoulderpad, if you like it, I'll glue it on. cheers, beork Link to comment https://bolterandchainsword.com/topic/180695-legs-and-fist/#findComment-2203023 Share on other sites More sharing options...
NeDlols Posted December 3, 2009 Share Posted December 3, 2009 Now thats a nice touch, I've already got plans for the fist but I think it'd look great on the leg but on the other one tho :) Link to comment https://bolterandchainsword.com/topic/180695-legs-and-fist/#findComment-2203285 Share on other sites More sharing options...
Brother_Beork Posted December 3, 2009 Author Share Posted December 3, 2009 So on the right leg it is then? Good, I'll stick it on tomorrow (training tonight). cheers, Beork Link to comment https://bolterandchainsword.com/topic/180695-legs-and-fist/#findComment-2203390 Share on other sites More sharing options...
Dragonkin Arenis Posted December 3, 2009 Share Posted December 3, 2009 He's gonna be an Ultra-smurf (nothing like the good old 40k posterboys) That's the Crimson Fists, actually... But the Ultrasmurfs have overtaken them, sadly... I'm loving this work, beork, it's extremely good :) Arenis Link to comment https://bolterandchainsword.com/topic/180695-legs-and-fist/#findComment-2203929 Share on other sites More sharing options...
Brother_Beork Posted January 18, 2010 Author Share Posted January 18, 2010 As good as done! Anything to add? last minute changes? Photo's aren't perfect, I'm not working with a normal camera right now, if you'd prefer to see better quality pictures you'll have to wait a bit until I get a new charger for my camera (hopefully this week). I really like how the tabbard/tassel thingy worked out, took me 5 tries, but I really like the sense of movement it gives. Some pictures: http://img.photobucket.com/albums/v331/brother_beork/Commissions/Bits%20and%20Pieces/100_8457.jpghttp://img.photobucket.com/albums/v331/brother_beork/Commissions/Bits%20and%20Pieces/100_8456.jpg http://img.photobucket.com/albums/v331/brother_beork/Commissions/Bits%20and%20Pieces/100_8459.jpghttp://img.photobucket.com/albums/v331/brother_beork/Commissions/Bits%20and%20Pieces/100_8458.jpg http://img.photobucket.com/albums/v331/brother_beork/Commissions/Bits%20and%20Pieces/100_8461-1.jpg http://img.photobucket.com/albums/v331/brother_beork/Commissions/Bits%20and%20Pieces/100_8455.jpg http://img.photobucket.com/albums/v331/brother_beork/Commissions/Bits%20and%20Pieces/100_8454.jpg http://img.photobucket.com/albums/v331/brother_beork/Commissions/Bits%20and%20Pieces/100_8453.jpg http://img.photobucket.com/albums/v331/brother_beork/Commissions/Bits%20and%20Pieces/100_8452.jpg http://img.photobucket.com/albums/v331/brother_beork/Commissions/Bits%20and%20Pieces/100_8455.jpg And if he'd be fully dressed: http://img.photobucket.com/albums/v331/brother_beork/Commissions/Bits%20and%20Pieces/100_8463-1.jpghttp://img.photobucket.com/albums/v331/brother_beork/Commissions/Bits%20and%20Pieces/100_8464-1.jpg http://img.photobucket.com/albums/v331/brother_beork/Commissions/Bits%20and%20Pieces/100_8466-1.jpghttp://img.photobucket.com/albums/v331/brother_beork/Commissions/Bits%20and%20Pieces/100_8465-1.jpg Link to comment https://bolterandchainsword.com/topic/180695-legs-and-fist/#findComment-2252438 Share on other sites More sharing options...
Brother Loring Posted January 18, 2010 Share Posted January 18, 2010 I really hope you are going to put an ultra U-Shaped footprint in whatever type of base you place it on. That would be awesome! Link to comment https://bolterandchainsword.com/topic/180695-legs-and-fist/#findComment-2252442 Share on other sites More sharing options...
Surreal Cruelty Posted January 20, 2010 Share Posted January 20, 2010 I looks pretty nice, though the powerfist looks too long..maybe shorten the part between the elbow pad and the fist? Link to comment https://bolterandchainsword.com/topic/180695-legs-and-fist/#findComment-2254082 Share on other sites More sharing options...
MRCHAOS Posted January 20, 2010 Share Posted January 20, 2010 The work put into this is amazing but I have to agree with Surreal Cruelty and say the power fist arm is a bit too long, but everything else is just awsome! Link to comment https://bolterandchainsword.com/topic/180695-legs-and-fist/#findComment-2254728 Share on other sites More sharing options...
Terminatorinhell Posted January 20, 2010 Share Posted January 20, 2010 I think you should have left the fist as is to be honest. Link to comment https://bolterandchainsword.com/topic/180695-legs-and-fist/#findComment-2254947 Share on other sites More sharing options...
Capt. Lysander Posted January 21, 2010 Share Posted January 21, 2010 I really like the powerfist. He looks great- it's cool how he has an Ultra symbol at the bottom of his heel. Link to comment https://bolterandchainsword.com/topic/180695-legs-and-fist/#findComment-2256044 Share on other sites More sharing options...
