chosonofchaos Posted October 6, 2009 Share Posted October 6, 2009 this is my tutorial on battle damage for chaos or space marines if you use this please practice first on an unwanted model or learn the hard way like me you will need a sharp pointed blade (i use a scalple) and a 1.4mm drillbit or screwdriver i will show you using a shoulder pad start with your cleaned model (do each piece separatly before assembling) first make an indent by twisting the point of the blade on the same spot (should be about 1.4mm wide) next, drill a hole about 1 and a half mm deep or as deep as you want(drill all the way through for shoulder pads) finaly use the blade at a 45 degree angle around the hole in a circle here are some pictures of my chaos aspiring champion with battle damage (sorry for blurry pictures) thanks for reading goodluck :D Link to comment https://bolterandchainsword.com/topic/180733-modeling-battle-damage-bolter-impacts/ Share on other sites More sharing options...
Harald Fairmane Posted October 11, 2009 Share Posted October 11, 2009 nice Link to comment https://bolterandchainsword.com/topic/180733-modeling-battle-damage-bolter-impacts/#findComment-2146875 Share on other sites More sharing options...
