Jangalak Posted October 6, 2009 Share Posted October 6, 2009 I was playing against my mates IG Army and he fields a vendetta with the 3 TL Lascannons. We were uncertain about the firing arcs for these despite a search of his codex - can anyone clarify what the firing arcs are for the two wing mounted las and the single 'nose' mounted las are? It looks as though the 'nose' las just piints straight ahead with little room for aiming unless the vendetta moves. Whilst the wing mounted las look like they either have a 45degree arc from the front or are possibly 360 degrees. Can anyone help? Link to comment Share on other sites More sharing options...
avatar8481 Posted October 6, 2009 Share Posted October 6, 2009 probably like all hull mounted weapons, 90 arcs bisected by the line extending from the barrel straight forward. Link to comment Share on other sites More sharing options...
Commander Remiel Posted October 6, 2009 Share Posted October 6, 2009 Check the main rulebook. It has a section on fire arcs based on mounting type. Link to comment Share on other sites More sharing options...
Cale Posted October 6, 2009 Share Posted October 6, 2009 Remiel is right, Avatar is mostly wrong. The Vendetta's weapons are hull mounted, and thus follow the rules for hull mounted weapons, which gives them 45 degree arcs of fire, which is to say that each can fire in exactly the direction it is pointing or up to 22.5 degrees clockwise or 22.5 degrees counterclockwise from the direction in which it is pointing. Link to comment Share on other sites More sharing options...
Jangalak Posted October 6, 2009 Author Share Posted October 6, 2009 Thanks to all, that makes sense. We rolled off for it in the last game and he got an extra 3 LC shots off at my dread, luckily for me they all failed to damage! Link to comment Share on other sites More sharing options...
Steelmage99 Posted October 10, 2009 Share Posted October 10, 2009 Remiel is right, Avatar is mostly wrong. The Vendetta's weapons are hull mounted, and thus follow the rules for hull mounted weapons, which gives them 45 degree arcs of fire, which is to say that each can fire in exactly the direction it is pointing or up to 22.5 degrees clockwise or 22.5 degrees counterclockwise from the direction in which it is pointing. While I agree that they should count as being hull mounted, it doesn't says so anywhere. Link to comment Share on other sites More sharing options...
HiveFleetEzekial Posted October 10, 2009 Share Posted October 10, 2009 Well they aren't provided on any sort of swiveling mount like a turret or pintel mount, the track rails on attack bikes and land speeders or even the Valk/Ven's own heavy bolter 'sponsons' (even the FW vendetta upgrade, as far as I can tell). They are fixed to the hull/wings unless the player purposefully modeled them to swivel way, which goes beyond the rules into 'opponent consent'. Link to comment Share on other sites More sharing options...
Steelmage99 Posted October 10, 2009 Share Posted October 10, 2009 The problem arises because GW tells us, in the rulebook, that individual vehicle entries in the relevant codexes will tell us the type of mounting of their weapons......and then they, in their infinite and holy wisdom, chooses not to do so. Link to comment Share on other sites More sharing options...
Interrogator-Chaplain Ezra Posted October 10, 2009 Share Posted October 10, 2009 The problem arises because GW tells us, in the rulebook, that individual vehicle entries in the relevant codexes will tell us the type of mounting of their weapons......and then they, in their infinite and holy wisdom, chooses not to do so. The rule book also says to use the actual arcs the weapons can rotate. In the case of the Vendetta, they can't. Which implies either hull-mounted, or, if you want to be a RAW advocate, just firing straight ahead without any arcs. Link to comment Share on other sites More sharing options...
King Tiger Posted October 10, 2009 Share Posted October 10, 2009 and then they, in their infinite and holy wisdom, chooses not to do so. they probably expect players to have some common sense are they mounted on turrets.....no are they mounted on pintles.....no are they mounted in sponsons.....no are they mounted to the hull of the aircraft.....yes therefore common sense (something so rare its a super power) shows us there hull mounted and would follow hull mounted rules.....TA-DA!!! Link to comment Share on other sites More sharing options...
Cale Posted October 10, 2009 Share Posted October 10, 2009 they probably expect players to have some common senseare they mounted on turrets.....no are they mounted on pintles.....no are they mounted in sponsons.....no are they mounted to the hull of the aircraft.....yes therefore common sense (something so rare its a super power) shows us there hull mounted and would follow hull mounted rules.....TA-DA!!! That's basically how I approached it. I'd prefer it if they had bothered to specify what type of mounting the guns get, but, barring that, we really have no choice but to ask ourselves how the guns are actually mounted on the model. In this case, they're pretty much hull-mounted, and that's both an easy and a reasonable answer to the question. Link to comment Share on other sites More sharing options...
nighthawks Posted October 10, 2009 Share Posted October 10, 2009 as far as the "they failed to tell us" argument goes, the biggest "possible" problem, for all of you RAW junkies out there, is the SM / SW etc... tank entries where the models "may take any of the following: A storm bolter, A [HK] missile, A multi melta," etc... precedence on the models shows NON pintle NON turret mounted SBs and HKs all the time (hatch mounted and bolted to the side of the turret most frequently, respectively.) now, we all "know" that these are pintle-mounted, or at the very least on a dedicated turret, but the lack of specificity CAN matter around here... but yeah, letting it slide and having fun really is the way to go. Link to comment Share on other sites More sharing options...
Cale Posted October 10, 2009 Share Posted October 10, 2009 Eh, I play my pintle-combi-bolters as hull mounted all the time. It's occasionally irritating, but never really important. After all, it's just a combi-bolter. I don't need to ever take any shots at all with my Rhinos to make them worth bringing. Link to comment Share on other sites More sharing options...
chapter master 454 Posted October 10, 2009 Share Posted October 10, 2009 therefore common sense (something so rare its a super power) You, sir, made my day with that Anyway, I would assume that as in king tigers post said it's a hull mounted weapon and thus has a 45 degree arc (and to whom this may be a problem you normally point the forsaken weapons at the target anyway in the movement phase!). yes the RAW people will have certain dreams over trying to deny you it but tell them to be RAW about the most important rule: have fun! Remember children, if the weapon in question can rotate before being glued in (IE doesn't have a fixed mount point) then it can rotate. Trust me, if thats bad try having to argue to some newbie that shooting through the window of a building (with no other means of seeing target) at my land raiders lascannons negates my cover save. Did nothing to the raider and I promtly fired back with the same logic and plastered the dark lancing git! Link to comment Share on other sites More sharing options...
Cale Posted October 11, 2009 Share Posted October 11, 2009 On the Rhino issue, note this FAQ from the March 2009 40K Rulebook Errata/FAQ document per GW: Q. On page 59, the rules for the arc of fire of pintle-mounted (or bolt-on) weapons address those mounted on turrets and those mounted directly on the hull. But what about those mounted on smaller structures (like a Rhino’s cupola) that look like they can rotate 360º, even though they aren’t proper turrets? A. Remember that the rule is: if it looks like you can point the gun at it, then you can, even if it’s glued in place’. The rest is just a set of guidelines about the arcs of fire of weapons glued in place, and does not cover all possible weapons mounting and vehicles. If the structure the gun is pintle-mounted on is obviously capable of rotating 360º, like in the case of a Rhino’s cupola, then it should be treated as having a 360º arc of fire. However, if you mount the same storm bolter on a Razorback, even though it still can rotate 360º, it won’t obviously be able to fire through the Razorback’s main turret, and so it will have a ‘blind spot’. In the same way, the shuriken catapult mounted under the hull of a Wave Serpent, Falcon, etc. looks like it can rotate 360º, but it does not look like it can be fired through the main hull right behind it, so we normally play that it can be fired roughly in the 180º to the vehicle’s front, which seems like an acceptable compromise. So, actually, I've been playing my Rhinos with an unnecessary handicap. Good to know. Link to comment Share on other sites More sharing options...
Frosty the Pyro Posted October 11, 2009 Share Posted October 11, 2009 The big problem with them not specifying the type of mounting for guns in the codex is not an issue of common sense, its an issue of this. Q: How much effort would it take to remodel the vendetas lascanons to BE on a turret. A: Very little. Heck people already change the position of sponsons to get better fireing arcs, its not a huge step to model turrets for unspecified weapons. Link to comment Share on other sites More sharing options...
rat of vengence Posted October 11, 2009 Share Posted October 11, 2009 The big problem with them not specifying the type of mounting for guns in the codex is not an issue of common sense, its an issue of this. Q: How much effort would it take to remodel the vendetas lascanons to BE on a turret. A: Very little. Heck people already change the position of sponsons to get better fireing arcs, its not a huge step to model turrets for unspecified weapons. I believe this has already been answered by HFE; They are fixed to the hull/wings unless the player purposefully modeled them to swivel way, which goes beyond the rules into 'opponent consent'. Unless of course you think I can model my demolisher cannon onto a predator turret and use it with 360 degree arc of fire? :) RoV Link to comment Share on other sites More sharing options...
King Tiger Posted October 11, 2009 Share Posted October 11, 2009 The big problem with them not specifying the type of mounting for guns in the codex is not an issue of common sense, its an issue of this. Q: How much effort would it take to remodel the vendetas lascanons to BE on a turret. A: Very little. Heck people already change the position of sponsons to get better fireing arcs, its not a huge step to model turrets for unspecified weapons. actually that still is an issue of common sense, your not supplied with a way to just make them turrets (or in your second part to make sponsons gets better LOS angles), you have to purposely go and make them turrets (or change sponson layouts/designs), common sense tells us if your not supplied with bits to actually do this, your probably not supposed to do it. Link to comment Share on other sites More sharing options...
