Good werewolf models out there ?
whitewolfmxc
As topic , i run a 13th company army , so i was thinking using a Giant werewolf model as count as canis wolfborn , so obviously the model has the be big enough (and scary enough) to fit the base and the role
so any good models out there ? it would be nice to know thier sizes too
https://bolterandchainsword.com/topic/180975-good-werewolf-models-out-there/
May I suggest the Hordes range, by Privateer Press, in particular the Circle of Orboros army.
older metal models are larger, but smaller than a dreadnought. The newer plastics are a little bit smaller though. Rackham is still going strong, just not as strong in the U.S. Check out eBay and you'll probably find some good deals on there if your local shop doesn't sell them. Personally I would get the metal figures if possible, they are fabulous models and the range is far greater than the plastics. Hordes warp wolf is a huge model when compared to 40K scale.
After looking around a bit I couldn't locate it, but I've seen a Wulfen model made from the body of a krootox, the head and tail of a fenrisian wolf, and a bit of green stuff. It was actually far, far better looking than it sounds, and I've actually contemplated using a similar conversion to portray Thunderwolves.
ive just bought a warpwolf model on ebay , id see would it fit the image of what i want , and hopefully ill take some pictures when it gets here
Grey mage : you mean this one http://www.reapermini.com/Miniatures/Warlord/sku-down/14528 ? yeah its too small , but it could be a wulfen model ? xd
  • 2 weeks later...
The warhammer skaven rat ogres make pretty good werewolves, with a goblin wolfrider wolf head, need some greenstuff fur in between the head and body, and some more fur to cover the wounds and boil stuff. The tail also needs fixing, either fur the rat tail up or use a wolf tail.
I have built a few to use as werewolf ogryns.
I would go for the Worg Models from Rackham if you can find them anymore. Rackham went ahead and discontinued their ENTIRE METAL LINE. Reason why I stopped playing Confrontation. There were 2 Lines that you might want to check out the Wolfen and the Devourers. There was also something called the Black Wolf for the Undead, but I haven't seen it and Rackham is being really slow about their new releases.
That big burly guy is Y'narhl, he is supposed to be an immortal, cursed by the moon for his savagery against his own kind.
