Silvtalon Posted October 9, 2009 Share Posted October 9, 2009 Okay what is the base size of these models? They are easily small enough to fit on the standard trooper bases, but in the codex it says they take up to slots in a vehicle when given to characters. If this is the case... Is it terminator size bases or troop bases we use? I think more along the lines troop due to the fact they are only 1 wound models.... I couldn't find the post that had the answer to this.... If it exists sorry for repeat. Link to comment https://bolterandchainsword.com/topic/181145-fenrisian-wolves/ Share on other sites More sharing options...
EricBasser Posted October 9, 2009 Share Posted October 9, 2009 I use the termie sized bases. Not too sure about this one either though. Link to comment https://bolterandchainsword.com/topic/181145-fenrisian-wolves/#findComment-2144923 Share on other sites More sharing options...
dublindawg Posted October 9, 2009 Share Posted October 9, 2009 I have seen a lot of people placing them on either a fantasy mount base or the rounded edge base for bikes. Link to comment https://bolterandchainsword.com/topic/181145-fenrisian-wolves/#findComment-2144929 Share on other sites More sharing options...
Crimson Devil Posted October 9, 2009 Share Posted October 9, 2009 I used Terminator bases (40mm) Link to comment https://bolterandchainsword.com/topic/181145-fenrisian-wolves/#findComment-2144931 Share on other sites More sharing options...
The Big Mek Posted October 9, 2009 Share Posted October 9, 2009 Phil Kelly used Termie bases, so they're probably good to go. I'd probably put them on cavalry bases though! Link to comment https://bolterandchainsword.com/topic/181145-fenrisian-wolves/#findComment-2144934 Share on other sites More sharing options...
Silvtalon Posted October 9, 2009 Author Share Posted October 9, 2009 Phil Kelly used Termie bases, so they're probably good to go. I'd probably put them on cavalry bases though! I just put one on a normal base for troops since I had one lying around. It seams to fit quite nicely easily enough room for the feet to fit. The only thing that sicks out past the base is the Head and tail.. :P Other wise the model stands up with out any problems and looks good. I looked at it on a termi base and found it slightly to big. Meh.. Calv bases were okay.. but didn't fit.. the look to well I am not into fantsy. Link to comment https://bolterandchainsword.com/topic/181145-fenrisian-wolves/#findComment-2144944 Share on other sites More sharing options...
AnarchX Posted October 9, 2009 Share Posted October 9, 2009 My Wolves are the ones from GW and they come with a Calvary base which is the rectangular WFB base or the same base that Bikes used to come with. Thanks, AnarchX Link to comment https://bolterandchainsword.com/topic/181145-fenrisian-wolves/#findComment-2145008 Share on other sites More sharing options...
Spacefrisian Posted October 9, 2009 Share Posted October 9, 2009 Yep rectangular base. Not to mention you must use that one as it was provided with them. Link to comment https://bolterandchainsword.com/topic/181145-fenrisian-wolves/#findComment-2145070 Share on other sites More sharing options...
