infiltraition
Depends on the USR.
Check rulebook p75. If the USR has a '*' by it, that means if an IC without that special rule joins a unit that already has it then the unit loses that ability. It also means the IC loses the ability (if he has it) should a unit he joins not already have it. If an IC joins to a unit and they both already have the same USR – even if asterisked – then they can both still use it
Cheers
I
https://bolterandchainsword.com/topic/181620-infiltraition/#findComment-2149880
