RastlinD Posted October 13, 2009 Share Posted October 13, 2009 I was playing a game last night and we ran across a question. Can a space marine chapter master use his orbital bombardment while in a transport with no fire points. Such as a land raider or a razorback. Thanks, also if you could please provide a page reference in the rules where the answer is found. Link to comment Share on other sites More sharing options...
OwlandMoonGuy Posted October 13, 2009 Share Posted October 13, 2009 In Codex: Space Marines, pg. 52, “Calling down an orbital bombardment otherwise counts as firing a ranged weapon and uses the following profile:” The BRB pg 66 provides the rules for firing ranged weapons from within a Transport, check under the heading, Fire Points. There are several limitations mentioned, first and foremost that a Fire Point is required. Note that Orbital Bombardment is a Barrage weapon so it does not require LoS. Despite that fact, a Fire Point is still required for any/all shooting attacks made from a model embarked in a transport. So the answer no, a Chapter Master cannot fire OB from within a Razorback or Landraider. -OMG Link to comment Share on other sites More sharing options...
