Must Charge and Bloodclaws
MechSpacewulf
OK, My buddy has been thinking way too much about this and asked me to post this question, my answer to him is NO however am I missing something?
"On page 95 of the rule book it says "in that turns assault phase ,however units may not launch an assault{even if they have fleet special rule}, unless clearly stated in their special rules".
My group says that the blood claws berzek charge says must charge if with in range,means they have to charge. Must means must even when disembarking from a Rhino or Drop Pod."
Thoughts, opinions, and statements for my battle brother.
https://bolterandchainsword.com/topic/181638-must-charge-and-bloodclaws/
Units can not charge the turn they deep strike without a special rule to override that. Blood Claws don't have a special rule to override the deepstrike restirction. Likewise, they can not charge if they fire a rapid fire weapon, or get out of a rhino/razorback after it moved.
The question is whether or not Berzerker Charge is such a special rule.
Does it say it overrides the restriction (like Vanguard Veterans do?) No. It doesn't.
Does Berserk charge implicitly state that BC can charge after a deepstrike or from exiting a non-open topped vehicle? If it does then charge all you want. If it doesn't then I'd say no.
Think about it in this logical sequence.
Movement Phase
The Blood Claws move, either walking, Deep Striking from a Drop Pod, or moving via and disembarking from a Transport.
Shooting Phase
Before you shoot any weapons or run, look at your Blood Claws unit. Are they within 6" of an enemy unit? (as per the rules, you would be able to measure this before any shooting is declared.)
If yes, is there anything that might preclude them from charging (re: disembarking from a moving transport, or entering play via Drop Pod)?
Assault Phase
If there has been nothing to preclude them from charging (as considered above in the Shooting Phase), the Blood Claws may assault/charge anything in range.
The key line is, on page 25, this (emphasis mine):
The pack must attempt to launch an assault in the ensuing Assault phase if at all possible...
DV8
Well said DV8.
I've played wolf players who want to fire blood claws plasmaguns at a nearby unit that isn't the closest then say they have to charge the closest and charge a new unit, despite the rapid firing restriction and the charge what you shot restriction,
Well said DV8.
Yea those scrupulous and shifty "Wolf" players have no honor, and aren't real Space Wolves. They should be stripped of title/rank and thrown into the winter-cold of Fenris to face the judgment of the were and the wulfen. :lol:
DV8
Well said DV8.
dammit, more reports of those chaos wolves... you know the ones they made up in the last C:CSM to go along with their frankly preposterous idea that 'apparantly' huron blackheart made a whole bunch of wolves repent their oathes... now they are tryng to ruin the good name we have built up of the last decade+
Thanks,
Remember that units can move, shoot and assult from a vehicle they have disembarked from that has not moved. Thanks for the input.
so disembark 2", move up to 6", shoot assault weapons, charge in and assault up to 6"= 14" potential
Movement Phase
Shooting Phase
Assault Phase
DV8
Thanks,
Movement Phase
Shooting Phase
Assault Phase
If in range the blood claws would have to (if they were in a rhino) disembark to charge the closest unit in the assault phase correct? they would not have a choice unless a wolf guard etc is with the unit to override their rule
DV8
Thanks,
Movement Phase
Shooting Phase
Assault Phase
DV8
Why do people do this? Quote verbatim someone else's post and add nothing to the discussion at hand, if nothing else just to get your post count up. Quality of posts, not quantity, is what counts. If you have nothing to add, don't post at all.
DV8
Just because a unit of Blood Claws is within 6" of an enemy unit does not mean that all the conditions that would allow them to assault have been met. So no assaulting after deep strike or assaulting after disembarkation from a moving vehicle.
K i might of missed something but some one said "shoot assault weapons".... not with the the blood claws, if they are within 6 inches of an enemy they forgo their shooting phase.
which raises my question of: if i put my bloodclaws in a drop pod and they end up within 6 inches of an enemy can they still shoot? remember pistols count as assault 1 now....
Well since you can't assault when deploying out of a drop pod you ignore the Headstrong rule (since you can't assault out of a drop pod) and can I think therefore shoot in the shooting phase that the drop pod lands.
The main reason is because since a unit can't "prepare for a charge" they can't mount......
I would say that the Headstrong rule is overwritten by the Deep Strike which would also include overwrite the restriction on not being able to shoot.
Well said DV8.
Yea those scrupulous and shifty "Wolf" players have no honor, and aren't real Space Wolves. They should be stripped of title/rank and thrown into the winter-cold of Fenris to face the judgment of the were and the wulfen. :(
DV8
Theyre also not playing by the new BC rules. As it specificly states unless they have a babysitter they CANNOT fire if a unit is within 6", wich happens to be there charge range. Its not, they cant fire if theres a unit within 6" unless that unit is- they just cannot fire.
UNLESS They have a character with them- be it an IC or a WG. Then, not only can they shoot at whatever they want, they can also assault or not as they please.
Because GW noticed the people who took plasmaguns in their packs for the last decade and used them to avoid making unfavorable charges.
Honorless, cheating, and hopefully just mistaken and in need of a good lesson.
