DarkMoonlight Posted October 13, 2009 Share Posted October 13, 2009 hi all bought a world eaters dread and games day this year and has anyone got ne ideas how i can go about converting it to make it looking as if its running? its a fw one if that helps. Link to comment https://bolterandchainsword.com/topic/181656-running-dreadnoughts/ Share on other sites More sharing options...
cathar the great Posted October 13, 2009 Share Posted October 13, 2009 RTFM Both your topics are requests, no tutorials. But if this eventually gets transferred to the Questions sections, there are a few conversions áround here on the forum, just do a search for dreadnoughts and browse through your finds, I'm sure you will eventually find what you are looking for. ^^ Link to comment https://bolterandchainsword.com/topic/181656-running-dreadnoughts/#findComment-2150364 Share on other sites More sharing options...
asmodai650 Posted October 14, 2009 Share Posted October 14, 2009 Use a modeling saw and cut one of the legs flush with the bottom of the knee. Sand the knee area smooth and drill holes in the knee and lower leg so that it can be pinned further back on the knee. You can stop here, or you can make it look even better by carefully cutting the toes on the moved leg so that they are in a more closed position like they are about to grab the ground when the leg touches down again. The forge world resin make this conversion easy to do because the resin is softer than plastic and, for me, easier to work with. I'll post pictures when I get home from work tonight. Be sure to either cut the material outside in open air or wear a mask when cutting, sanding, or filing any resin models. Link to comment https://bolterandchainsword.com/topic/181656-running-dreadnoughts/#findComment-2151527 Share on other sites More sharing options...
DarkMoonlight Posted October 17, 2009 Author Share Posted October 17, 2009 thanks asmodai gonna bare that in mind and give it a go. i managed to get some plastic dread legs so gonna practise on them but pictures would be great!! Link to comment https://bolterandchainsword.com/topic/181656-running-dreadnoughts/#findComment-2154732 Share on other sites More sharing options...
asmodai650 Posted October 17, 2009 Share Posted October 17, 2009 Here is a few pic that should help. Link to comment https://bolterandchainsword.com/topic/181656-running-dreadnoughts/#findComment-2154915 Share on other sites More sharing options...
The Angelus Sanctus Posted October 19, 2009 Share Posted October 19, 2009 Please read this. Link to comment https://bolterandchainsword.com/topic/181656-running-dreadnoughts/#findComment-2156196 Share on other sites More sharing options...
