Token Posted October 14, 2009 Share Posted October 14, 2009 The heavy bolters are so cheap for the long fangs, so i wrote a list with 5 in one unit, then some anti tank/heavy creature weaponens, missile launchers and lascannons, in another. Is it better to mix them up or have one anti infantry and one anti tank/heavy creature? Link to comment https://bolterandchainsword.com/topic/181805-two-diiffirent-kind-of-heavy-weapons-in-one-long-fang-squad/ Share on other sites More sharing options...
JamesI Posted October 14, 2009 Share Posted October 14, 2009 Since Long Fangs can split fire, mixing them up is ok. Link to comment https://bolterandchainsword.com/topic/181805-two-diiffirent-kind-of-heavy-weapons-in-one-long-fang-squad/#findComment-2151914 Share on other sites More sharing options...
Karack Blackstone Posted October 14, 2009 Share Posted October 14, 2009 While it is easier to field one type per LF pack, it can have rewards if you find it easier to squeeze multiple roles into each squad. I use a pack of 5 HB's and a pack of 5 LasC's myself. Link to comment https://bolterandchainsword.com/topic/181805-two-diiffirent-kind-of-heavy-weapons-in-one-long-fang-squad/#findComment-2151917 Share on other sites More sharing options...
dublindawg Posted October 14, 2009 Share Posted October 14, 2009 Mixing them up will help against enemies that can pie plate your packs. If one is taken out then you still have the other pack for mixed firing. Link to comment https://bolterandchainsword.com/topic/181805-two-diiffirent-kind-of-heavy-weapons-in-one-long-fang-squad/#findComment-2151918 Share on other sites More sharing options...
Thorgad Posted October 14, 2009 Share Posted October 14, 2009 You can mix them up as much as you want, but there's a few things to keep in mind. As long as the sergeant in the squad isn't dead, you can fire at two different targets with each squad of Long Fangs, so mixing up the different types of weapons can be a good tactic. Say, for example, that you take wounds on the squad, you can allocate them on the heavy bolters if you need your longfangs to be anti-tank, and vice versa if you need them to be anti-infantry. Generally I'd say, if you have two or more squads of Long Fangs, I would mix them up. Unless of course you WANT more of a certain type of weapon. Link to comment https://bolterandchainsword.com/topic/181805-two-diiffirent-kind-of-heavy-weapons-in-one-long-fang-squad/#findComment-2151920 Share on other sites More sharing options...
the great beaver Posted October 14, 2009 Share Posted October 14, 2009 the other thing I like to do is kill off the non lascannon fangs first so mixing up your squads gives you semi-ablative wounds that make it harder for your enemy to pick off your lascannons. on the other hand if everyone in the squad is taking the same weapons then you can off the pack leader right away to save a heavy. Link to comment https://bolterandchainsword.com/topic/181805-two-diiffirent-kind-of-heavy-weapons-in-one-long-fang-squad/#findComment-2151927 Share on other sites More sharing options...
greese_m0nkey Posted October 14, 2009 Share Posted October 14, 2009 I have seen allot of peaple say the set of 2HB, 1ML, and 2LC is a good mix, you can use the ML for both tasks of anti personel and anti vech. Link to comment https://bolterandchainsword.com/topic/181805-two-diiffirent-kind-of-heavy-weapons-in-one-long-fang-squad/#findComment-2151930 Share on other sites More sharing options...
PKAwolf Posted October 14, 2009 Share Posted October 14, 2009 im will soon be testing 2 units but they are more focused mix's 3x LC 2x ML anti tank while the ML gives a lil flexability and 3x HB 2x PC anti horde while the PC can put the hurt on something tough Link to comment https://bolterandchainsword.com/topic/181805-two-diiffirent-kind-of-heavy-weapons-in-one-long-fang-squad/#findComment-2151949 Share on other sites More sharing options...
Grey Mage Posted October 14, 2009 Share Posted October 14, 2009 I try to take two of one kind, and two missile launchers. Why? Because MLs can atleast try to hurt anything in the game, and theyre cheap. Makes them the perfect pair to any other HW. Link to comment https://bolterandchainsword.com/topic/181805-two-diiffirent-kind-of-heavy-weapons-in-one-long-fang-squad/#findComment-2151959 Share on other sites More sharing options...
Token Posted October 14, 2009 Author Share Posted October 14, 2009 Thanks for all the answers. Link to comment https://bolterandchainsword.com/topic/181805-two-diiffirent-kind-of-heavy-weapons-in-one-long-fang-squad/#findComment-2152003 Share on other sites More sharing options...
