1000pts
Icewolf
Brothers,
My question is at 1000pts what is a better HQ option to take out of the wolf guard battle leader and a wolf lord. The options below is probably how I would run each character but the second wolf guard is more because it is possible on not too much more expensive and would be a real CC machine.
Wolf Lord
Frost Axe
Belt of Russ
Saga of the Bear
Total - 185pts
Wolf Guard Battle Leader
TDA
2x Wolf Claw
Saga of Warrior Born
Total - 165
TDA
2x Power Fist
Total - 175
Icewolf
https://bolterandchainsword.com/topic/181830-1000pts/
I like the first one. If you throw RA on him, it'll be essentially the same as TDA since you have a 2+ and an invulnerable b/c of the BoR.
Since the RA is the same size as power armor, I would assume SoH is OK, but you're better off asking the really old guys around here like TeamLando or Only_in_Death about that.
https://bolterandchainsword.com/topic/181830-1000pts/#findComment-2152272
The problem I have is I really like TDA but want to give my wolf lord a frost blade but cannot give both.
Also on a side not if a model has runic armour does that mean they cannot take the saga of the hunter.
Icewolf
Well, they're all listed as Infantry, and unless you give them a mount, bike or jump pack, they're still infantry.. So you could have them in TDA with Saga of the Hunter if you wanted.. You could also (probably) join said TDA HQ to scouts and outflank (though not OBEL)
https://bolterandchainsword.com/topic/181830-1000pts/#findComment-2152401
Icewolf
it specifically states that they cannot have TDA with hunter. TDA cannot lead scouts. please re-read that entry again.
https://bolterandchainsword.com/topic/181830-1000pts/#findComment-2152417
Icewolf
Ahh, ok, I took a closer look, I'd just read the rules for it on the list of sagas and in there it made no mention of not being able to take it in TDA..
https://bolterandchainsword.com/topic/181830-1000pts/#findComment-2152729
  • 4 months later...
You CAN!!!!! get a frost balde/axe with TDA!!! FAQ erratum section on GW's website! it states that you can and its the same price as Powerfist
Page 84, Wolf Lord, Options, fifth bullet point.
Change:
- Power fist…………10 points
to
- Power fist, frost blade or frost axe…………10
points
Page 85, Wolf Guard Battle Leader, Options, fifth
bullet point. Change:
to
points
It all good my brothers!!!!
https://bolterandchainsword.com/topic/181830-1000pts/#findComment-2299902
But, come to think of it, I'd rather use Runic, Frost Blade, and Storm Shield rather than TDA, frost blade, and Storm Shield. Costs the same if I'm not wrong (my brain isn't working well with math right now), but you get to do sweeping advance with runic armor. I personally use Saga of the Bear, although I some time switch it with Saga of the Warrior Born.
And btw, try google space wolves FAQ, and download (and print) one from GW. It's kinda stupid that they didn't review their mistakes earlier on and made an Errata and FAQ instead. Kinda bothers me.
https://bolterandchainsword.com/topic/181830-1000pts/#findComment-2299986
Change:
to
points
to
points
This is true. I was pondering using TDA with my wolf lord but i liked the appearance of runic armor. So i took runic, frost axe, belt of russ and saga of the beast slayer. for MC or T5.
https://bolterandchainsword.com/topic/181830-1000pts/#findComment-2300009
