SW Grey for Airbrush?
WolfLordLars
Posted in the painting forum, but figured I might get a bite here too...
Just picked up an airbrush setup and am wanting to use it to basecoat my Wolves... using Space Wolf Grey. So, as I see it, my options are:
1 - Water down Citadel/Vallejo paint enough to use in the airbrush
2 - Mix my own
The problem with 1 as I understand it is that both Citadel/Vallejo dont water down well to the consistency needed for an airbrush. Someone even told me that the pigment is so thick that clogging is an issue, though thats mainly with Citadel.
The Vallejo airbrush ready line doesnt have a Space Wolf grey, and so far I have been unable to find any other line of airbrush paints (or other paints which work well thinned down) that makes anything close.
Help?
https://bolterandchainsword.com/topic/181859-sw-grey-for-airbrush/
2 - Mix my own
Help?
40% paint - 60% water = citadel friendly airbrush paints.
Watch out for graveyard earth or what ever. The browns will clog like all hell.
Space Wolf Grey works fine with airbrush though, Also taimya Color x-20A thinner works GREAT. I do 50% water, 50%paint, then add that thinner as needed and it works great with my iwata .02mm Nozzle
There seems to be a bit of confusion from other posters as to whether you are talking about an airbrush or a GW spray gun. These are two completely different items. I recently started using an airbrush and was told that clogging is an issue with GW paints as it doesn't work well with thinner. I gave it a shot anyway and boy do I regret that mistake. It took me 10 minutes to clean the thing after and even now (2 months later) there is still a lot of paint in there that I just cant remove. As for a spray gun I wouldn't know though. I primarily use Tamiya paints for my airbrush but haven't really found an equivalent (though I have only tried 2 possibilities) yet. Some of the other posters should be able to help you there. But my recommendation is to NOT use GW or vallejo paint in your airbrush.
Use the following URL and pick a palette from the vallejo air range or another:
http://colors.silicon-dragons.com/full_line.php
You should be able to get an idea of what you want and order a couple of pots to test and mix up some batches of what you like. And yes, prime first.
Marek
2 - Mix my own
Help?
Believe me: use 50% Tamiya X-20A Thinner 50% Citadel paint (not Foundation). It works really fine, no problem at all with an 0.3 airbrush (dont forget to clean the airbrush by using alcohol and airbrush cleaner after each use/different mix).
I use a 5:1 mix of paint to water for my airbrush compressor unit and it seems to work fine whilst giving the colour I want.
I have an IWATA HP-BH. If my airbrush can do fine with Citadel paints, anyones can, and I just airbrushed for the first time 3 weeks ago, and I have yet to "clog" JUst have to mix correctly.
admitted that I have a pretty high quality airbrush, but I've not had any problem with using fresh pots of citadel paint thinned just a little with testors acrylic thinner. older pots where the medium hs evaporated need more thinner. You can also use an arylic medium to refresh your paints if need be.
I've not tried metallics or foundation paints, particularly I know foundation paints, because they have a different medium, will gel if they're exposed to acrylic thinner.
